Question about Honeywell Kitchen Ranges
Can I use Honeywell smoke detector TC807E1011 as convetional sensor and How?
Ss99hh67ss27dd34cc49 pls call me
Posted on Aug 18, 2014
  • satish
    satish Aug 18, 2014
    call 09967273449 and get the answer
Purchase honeywell smoke alarm tc49a
I could not find a recommended replacement for this device, but what i did find is that it appears to be well beyond 10 years old. NFPA72, the national fire code, specifies that all smoke alarms (as opposed to smoke detectors) must be replaced every 10 years. If you do not have the skills to do the job, you could look for a handyman, or better still, a licensed electrician to do it for you.
Feb 21, 2015 | Home
My alarm monitoring service tells me they are getting multiple sensor error readings from my smoke detectors. This occurs at the same time each morning. I have checked the voltage at the alarm panel
Before I can really try to answer, I would like to know what make/model control panel you have (ex: Honeywell Vista20P), the zone number of the affected smokes, and whether or not you get an indication of a problem on your keypad.
Nov 16, 2014 | Home
How do I troubleshoot an intermittent problem with a 2 wire system sensor smoke detector
Intermittent problems are often difficult even for professionals. That said, I would need more specifics on the problem if you want to continue on your own first. The model of the system, keypad indications, whether the problem is a trouble or alarm, what make/model the detectors are (there could be more than 1 type on a 2-wire fire zone), etc.
Oct 14, 2014 | Home
How to open449CSTE - Smoke Detector W/Heat Sensor, Sounder & Status Relay keeps going off from stean
Opening is simple, but I don't know what you expect to accomplish. Just insert a small flatblade in the vertical opening opposite the hinge side and press firmly to release. If the plan is to disable the device by removing the wires you will only create a trouble condition if your smokes have been wired correctly. More info about your intentions might be helpful.
May 22, 2014 | GE 449CSTE - Smoke Detector W/Heat Sensor,...
Fire alarm keeps going off randomly and there is no fire or smoke
What type of smokes detectors are you using. Is the Zone programmed correctly. Loose connection. Missising resister
Mar 09, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
How do you test a Honeywell smoke detector
Home Depot or Lowes sells "smoke in a can". Use it sparingly to test your smoke detector.
Apr 10, 2012 | Honeywell 5808w3 Photoelect. Smoke Heat...
I want to disable the remote sensor function on the first alert sa302. My tv remote keeps setting off my smoke detector
First you need to remove the battery, hold test button down while re-installing battery, when detector beeps,it disarms remote feature. Normal detector then. this should dissable the remote feature. this is a very common complaint. If for some reason it wont turn the remote off get a piece of tape to cover the sensor.
If your happy with this solution a vote for the thumb up would be greatly appreciated. Thanks for using Fix Ya
Jul 05, 2011 | First Alert SA302 Dual System Smoke...
Goes off only at night with NO warning cleaned & changed batt. 4 times so far !!!!
These types of smoke detectors are PHOTOELECTRIC, the way it works, there is a IR transmitter and a IR receiver placed in a dark chamber aligned at a 45degree angle, when smoke enters the chamber IR light bounces of the smoke and than generating an alarm, so in conclusion if there is a lot of DUST in the chamber it reflects the IR light just like smoke, than can generate an alarm, try blowing air in the smoke detector (gentely) if it does not work replace the smoke detector...
Feb 04, 2011 | System Sensor 2100rfadt Wireless Smoke...
Kitchen Ranges Logo
108 people viewed this question
Top Honeywell Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Honeywell Kitchen Range Expert? Answer questions, earn points and help others
