Question about Brother DCP 130C All-In-One InkJet Printer
IS TELLING ME IT HAS A PAPER JAM BUT NO JAM FOUND SOUNDS LIKE A SLIPPING COG
    Genius:
  • 2,785 Answers
Your paper sensor is having problem.your printer needs to be opened so take it to the service centre
Posted on Aug 19, 2010
Epson Stylus Photo PX800FW paper jam
Got my own PX800FW.
Please note that ADF paper jam online docs of EPSON Aculaser 1100 http://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/faq/2929/1393#toc6 are craph* more detailed than the PX800FW **** that EPSON is making users put up with.
I am having the very same ADF scanner jam issue (paper stuck directly when trying to feed into the lower rolls).
Initially I suspected the upper paper feed rolls (turning them requires rather strong force), but they were not the actual problem (see below).
If you want to inspect these top rolls, then remove the top flap
(use a screw driver to somewhat (and obviously carefully!) bend the plastic hold located towards the user panel side, then lift off top flap.
I then unscrewed its 4 screws.
To remove the main roller mechanism, you need to pull out (somewhat forcefully, but obviously carefully) the large white extended cog bar. Then push out the somewhat larger wheel bar from its flap-side plastic holder.
Now you\'re able to (while keeping a watch on the small white tab that\'s being drawn back by a spring) remove the entire roller skeleton.
I then proceeded with removing the end cap (fiddling with a screw driver - but watch out for some parts getting lost due to a somewhat strong spring!) and replaced the spring with a weaker one, and adding some washer plates reinforce the slightly weakish spring. I then ended up with a roller mechanism that was almost as strongly pressing the rolls towards paper, yet actually turning them ended up easier on the motor.
I then put everything back together, but an attempt with the newly replaced parts failed, too.
Then I directed my attention towards the main motor / cog mechanism.
I rather instantly had to discover that the main cog at the main ADF motor was broken, and this is very likely to be the reason for the ADF jam issue.
This rather flimsy black cog is made of plastic (and having some nice tiny predetermined breaking point holes to boot!! guess where it did break...) and sitting on a metal drum which seems to be rather strongly attached to the main motor axis, unfortunately.
I will now try to remove the drum, possibly with the help of hopefully successfully warming it via a hair dryer. Choosing to glue the original plastic cog instead doesn\'t sound like such a marvelous proposition...
Given the rather flimsy appearance of the entire printer a future EPSON choice is quite unlikely.
Oct 23, 2012 | Computers & Internet
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
Printer says to clear paper jam, can't see paper jam i clear it out.
Here is a post I found how someone else fixed their problem. Good Luck
I was getting the same fake paper jam and improper shutdown error messages on this POS printer. I blew it out with compressed air - but that was no help. To watch what was going on, I stuck a pen top in the open cover switch sensor (see top image at http://windowshopusa.com/hp_8500_POS.html ). It didn't appear that the cog wheel was the problem - it made no clicking noise or anything - the print head just traversed from R to L, then errored.
After I removed the sliding cover on the right, and with the print heads out of the way, I noticed that the chrome hold-down clip (bottom image) was crooked, and this prevented the print heads from traveling all the way to the right, causing the fake paper jam. Straightening the clip fixed the problem. (I didn't have to remove the clip, just pushed it straight - it's not in very tight.)
Nov 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My printer is telling me to remove paper jam, there is no paper jammed, when I try to print, it clicks repeatedly for ten or twelve clicks, and then tells me to remove paper jam?? It is a hp Officejet...
The sheet feed detector is bent out of true, which would start the error message, after checking that it touched the paper, see if the feed rollers are misaligned, or, are damaged. If there is a cog tooth drivebelt on this, see if the belt has snapped or is off the cog. After that, it could be a faulty sensor switch
Jul 05, 2011 | HP Office Equipment & Supplies
I have a HP psc 2410 Photosmart all-in-one. I keep getting a Carriage Jam error message! What do I do? It was sitting on a padded chair and shook alot when it was printing because it didn't have a...
Carriage Jam = the box that holds the printing heads is jammed. Since it was sitting on a shaky base my guess is that either the belt that moves the carriage has flipped out of its cog or a cartridge has goon loose and is out of the carriage blocking its movement, you must open the case and look for the cause.
Jun 13, 2010 | Office Equipment & Supplies
My 2600n laser printer had a paper jam in the outbox bin. I took the stuck paper out and had a look inside. I see no other paper jam but the printer keeps telling me I have a paper jam in the outbox. ...
There is a sensor flag (little black peice) that hangs down in the paper path as the paper exits. The flag tells the printer if the paper has made it out or not. That sounds like your problem. Just in case it is something else, her's a copy of the complete service manual for your printer. Start on page 90 (pdf page 113) and it goes thru the jam areas.
http://www.feedroller.com/Store/Service%20Manual/HP%20Color%20LaserJet%202600N%20(Q6455A)%20Parts,%20Service%20Manual.pdf
Nov 16, 2009 | HP Office Equipment & Supplies
Paper jam flasher
Henry, try blowing it all out with compressed air to clear jamb.
Nov 27, 2008 | Canon NP 7130 Black and White Copier
Paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
May 03, 2008 | Xerox Phaser 6180N Laser Printer
Paper jam.....
I think you might have a timing problem, ck. and clean reg. and all feed rollers, possible chultch slipping that drive the gears?
Feb 09, 2007 | Ricoh A2018D Black and White Copier
Brother DCP 130C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
