Question about Vizio L32 32 in. LCD HDTV
Vizio L32 TV started with going off and on by itself and now it will not come on even if I hit the power button on the set.
  • 1 more comment
  • Anonymous May 10, 2008
    My Vizio 42 inch is 6 months old and the screen turns off by itself (black screen) about every 5-10 minutes but the sound remains on! I can shut it off and turn it back on and it happens again 5-10 minutes later. IT's driving me insane! Is there some sort of timer on? Or is there an internal issue?
  • Anonymous May 12, 2008
    My Vizio L32 goes on and off about every 3 seconds. The power on light remains green during this cycling. I've unplugged all inputs and it continues to do this.
  • sbgibson Aug 31, 2008
    VIZIO 37" is 3 years old and keeps going out, power shuts off every few minutes, don't know if it's worth repairing or just get another, better brand. any suggestions? Scott
I had the same problem with my 32", eventually the power board assy. went bad. you can go to vance-baldwin.com or partstore.com and order the new power board for $80 wich includes a $15 core charge. It is a very easy part to replace, works good now.
Posted on Sep 04, 2008
    Problem Solver:
  • 12 Answers
I've got the same problem. I think we got what we paid for. It's either a power supply (internal) problem or an internal electronic board problem. Either way, Visio charges around $300 for the repair. I'd just save the $300 and put it toward a TV not sold at walmart.
Posted on May 08, 2008
My 32" vizio is several
The problem is that some Capacitors of the power printed circuit has gone off. You should give your TV to an expert near by you to change them. I'm sure that this is the only problem and the cost is cheap. Please Rate my solution! Thanks!
Apr 28, 2011 | Vizio L32 32 in. LCD HDTV
Tv turns on by itself
Unusual. most likely reason is a failure of the standby management chip which is a component of the sets power supply board, they usually blow up rather than initiate uncalled starts though. This needs examining by someone who has experience with flat screens. If you were to look at vizio l32 psu on google, you'd see why.
Jan 13, 2011 | Vizio L32 32 in. LCD HDTV
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
My tv won't turn on. The orange light is on - will not turn green and go on. Have tried disconnecting from power, using remote, manually hitting on button. Vizio L32 hdtv10a
Look at the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
I have the same model for my bed room, my power supply blew up beyond repair, had to buy a used one, now the LCD controller board is going bad when it gets hot. Not a very good TV.
Dec 01, 2009 | Vizio L37 Television
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging...
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Aug 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
No Power
It appears that the power supply is starting to fail. It is also possible that there is another board in the set that is over-loading the supply.
The nature of the fault indicates the strong possibility that there are some parts that have become thermo sensitive. This is not a reset problem going by your description. Unplugging the set, is allowing the boards to cool down, and therefore they will work for a while until the thermo sensitive parts heat up again.
Jerry G.
Mar 25, 2008 | Vizio L32 32 in. LCD HDTV
Television Powers Off While Watching
Possibly set was droped at sometime are just hit hard. Maybe loose connection in powersupply
Aug 08, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
209 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
