Question about Canon iR 1600 Laser Photo Printer
E000 IS DISPLAYED IN THE MACHINE - Canon iR 1600 Laser Photo Printer
  • 1,219 Answers
E000:
The main thermistor reading does not reach 40ºC 14 sec after the fixing
heater goes ON. (fixing low temperature error).
First you need to try reset the error code and the procedure for that is:
SERVICE MODE entry: MENU and #
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and turn
off and then on the power switch to clear the memory: #7 PRINTER>#4
PRINTER RESET>YES=(*).
If the error is still present after clearing, you need to dismantle fixing unit and check with universal voltmeter the lamp, by putting the DVM to buzzer mode and each ends of dvm probes put on ends of lamp, if it buzzs that means that there is connection and lamp is OK, so you need to focuse on thermistors and thermofuses or ... call service.
Hope that helps!
Posted on Aug 19, 2010
System error "E000"
Reset the device when it does not respond. If the device does not respond, disconnect and then reconnect the power cord. At the device or at the electrical outlet, disconnect the power cord or adapter. Wait approximately ten seconds and then reconnect the power cord. Wait until the device has completed its cycling process before submitting another job request. If this doesn't work try reseting If all else fails I would suggest taking it to a qualified service center. Hope this helps:) Jason
Aug 26, 2007 | Canon PC-D320 Copier
Canon ir 2520 error e00000 000
How to clear E000, E001, E002 and E003.
1-Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions.
#SSSW will be displayed.
2-Use the right arrow and scroll to #CLEAR then press OK.
3-Use the right arrow and scroll to ENGINE then press OK.
ERRCLR will be displayed then press OK.
4-Then power cycle the machine.
Service Mode : ADDITIONAL FUNCTIONS>2 KEY>8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ENGINE>ERRCLR.
Note: This mode should be used to clear all Fixing related Error Codes.
If this does not resolve the error code. / u need to call for service or if u are a tech--pull out the fix unit to inspect
Dec 04, 2014 | Canon Office Equipment & Supplies
Ir1600 copier displayed system error E000, therefore the copier couldn't operate
E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
Nov 13, 2010 | Canon iR1600-2000 PS
My Canon MF4350d is all stop for no reason and message system error E000 is displayed
E000 mean power supply problem to Fussier unite fixing film was broken or fuse burning so lamp is not on.
Dec 09, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
E code E000-00-0081
hi, check once again if it's E000-00-0081 code. i just looked in the service manual for that machine and there's no E000-00-0081 code. the only one pointing to E000 is this: insufficent temperature rise of the fixing unit at power-on.
the one pointing to 0081 is:
p-sens-p when value of this position is lower than 255 it will indicate an error code: E020-0081. you can check it in service mode which you can enter by pressing combination: *28*(star-28-star) try specifing some more detailes, e.g. when it occurs
Jul 24, 2009 | Canon imageRUNNER C3170I Color Copier
System error for cannon 1670f
Press the usermode star-the star just above the lcd display-and then # key,scroll with the arrows until clear is displayed press ok and scroll again untill ERR is displayed press ok,Swotch the machine off and on again.
Jun 30, 2009 | Canon ImageRUNNER 1670F Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
E000
e000 is fuser temperature too low could be disconnected or the over heat senser has to be replaced and this code must be reset in service mode to allow copier to function.
May 12, 2008 | Canon imageRUNNER 1630 Copier
Canon iR 1600 Laser Photo Printer Logo
117 people viewed this question
old marine
old marine
