Question about Sony Cyber-Shot DSC-P7 Digital Camera
Zoom function Hello, suddenly the monitor became blurred and the zoom doesn't work. I hear the gears trying to move but... Thanks in advance Chris
  • 849 Answers
Replace batteries...
Posted on Oct 24, 2008
Volkswagon passat not moving in drive/reverse mode
DOES THE INDICATION OF THE GEARS FLASH OR STAY LIT UP?
Mar 08, 2014 | 2001 Volkswagen Passat
Nokia E71 speaker suddenly stopped working
Hello Dev If the ringer of your phone works sometimes,there might be some sort-circuit with the ringer and the connector.....So, to fix this the best way to get rid from this problem is to contact mobile repairing shop because an ordinary person could not do this,it can damage easily when a non-expert technician do this thing.Good luck
Jun 26, 2012 | Nokia E71 Smartphone
When i zoom my cam in and out, it became blurder.
On a webcam, you will generally find that they don't have the optical zoom that you would find on a compact digital, or SLR camer. in most cases, the zoom that you have is digital zoom, this just increases the size of parts the image being fed to the computer, and will often become blurred after a certain point. the best advice would be to move closer to the cam, or to buy a camera with higher resolution...generally 5MP should be more than enough.
the other thing you should try first, is to check that the camera isn't out of focus by looking for a ring around the lens, on some models there will be an adjustable focus, if this is the case,rotate the ring until a desirable image is shown.
Apr 30, 2011 | Computers & Internet
Blurred Taking Pictures, But not all the time???
lens misallignment due to worn out gears on focus adjustment (zoom in/out), needs repair but could be expensive and not reliable enough.
May 20, 2009 | Casio Exilim EXZ75 Digital Camera
Blurred icon graphics
This is usually caused by windows display properties is operating incorrectly. One of the options is to default everything under your display options using control panel. If it still is blurred then try using the optimized screen resolution and enable the cleartype in Windows. If after doing that.. it remain blurred, try to use the Cleartype Tuner by Microsoft at http://www.microsoft.com/typography/...ePowerToy.mspx
See also http://www.microsoft.com/typography/...ner/Step1.aspx
Hope this helps. Let me know.
Mar 29, 2009 | Samsung SyncMaster 793DF 17" CRT Monitor
Power Issue?
unplug the satellite cables and restart the dvr. if the dvr powers up plug in the cables when u see searching for satellite.
Oct 11, 2008 | Directv HR10-250 DTV Receiver
ADSL X6
presuming that the router moved with you the telephone line socket could be too far away from the BT socket or is not correctly wired. if you have not moved the router then you need to buy a booster
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
Zoom Problem
The zoom are lock due to sudden dropped , the moving parts of the zoom dislocate or broken, the zoom malfunction,you try visit some camera juck shop or repair shop same brand to replce broken parts.
Dec 23, 2007 | Olympus FE-280 Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Sony Cyber-Shot DSC-P7 Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
