Not allowing heat option on the ONIX split air-conditioner, model : AUS-12H53F130D(AZ)
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
SOURCE: Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Posted on Feb 10, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
My gree mini split 2400 heat pump air conditioner does not turn off at the set temperture when cooling
I am not sure about your specific model. However most A/C units I have worked with have a fan switch. The switch allows you to choose to have the fan on all the time or only when the unit is cooling. Some of these switches are behind the front panel, behind the panel or out in the open it should be close to the other controls. Hope this was helpful.
May 24, 2014 | Gree 24,000 BTU 18 Seer Ductless Mini...
Owner manual onix evaporative cooler
The Onix (Sold at Coles) is identical to the Home Maker FSH-90R (Sold at K-Mart). You can download the Home Maker FSH-90R/Onix user manual at the address below; just search for FSH-90R in the manuals section option under cooling products.
http://www.tempoaustralia.com.au/onix-products/cooling/evaporative-air-cooler
Direct PDF link as of May 2013:
http://www.tempoaustralia.com.au/manuals/onix//Cooling/FSH-90R.pdf
Hope this helps.
Nov 14, 2011 | Heating & Cooling
What does a df error code stand for on a con-air heat cool split system wall mount
Friend!,
Please ensure with your model/brand and error code. To my knowledge and web search, I don't find tour model on market. Don't be angry, plz check once again and write back.
Dec 15, 2010 | LG LSC183VMA Split System Air Conditioner
We have a split system and can not figure out how to heat different zones (ie bedrooms). Can you please help?
what kind of split system do you have is it a ductless split like shown or do you have actual duct work where you can change the dampers
Sep 18, 2010 | Sanyo Split System Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
