Question about HP LaserJet 4300 Printer
Printer keeps saying cartridge error - HP LaserJet 4300 Printer
    Problem Solver:
  • 17 Answers
It is probably a defective cartridge. There is a chip on the cartridge that is most likely bad.
Try pushing the green button to bring the machine to Ready. If that doesn't work than you have a bad cartridge
Posted on Aug 19, 2010
4 Suggested Answers
  • 35 Answers
SOURCE: Printer cartridges
Are you trying to use brand new HP cartridges? If you are using an off brand cartridge (even if it says it will work with an HP printer) these do NOT always work. If they are HP brand then you might not be removing the plastic from them all the way (check for plastic covering the metal contacts on the bottom and the back of the cartridge which could be imparing contact). Also, make sure you are seating them properly. Some cartridges require you push them firmly into place. It shouldn't take a LOT of force to do so, but it would require more then just sliding it into place.
Posted on May 09, 2008
SOURCE: I keep getting cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Posted on Oct 11, 2008
  • 1751 Answers
SOURCE: my printer keeps on saying cartridge error
hi my friend
you need to replace one or both of your cartridges with new ones
if you have the old you can check , what cartridge couse the error and you can refill the old one like this
if i helped you pls vote
Posted on Oct 30, 2010
I need Help fixing my HP Officejet 4215 All in One it keeps saying Cartridge Error and wont let me print anything.
Try reinstalling the printer drivers and software and plug connecting to the pc too
If problem still persist
There may be a problem in the cartridges holder
Then you have to connect with the customer care of the printer.
Or have to buy new printer easily and cheap at ebay
Aug 29, 2015 | HP OfficeJet 4215 All-In-One InkJet...
I keep getting a msg saying carterage error on my printer
If you DID NOT use a HP cartridge you get the error message.
If you did use a HP cartridge. Unplug the printer. Wait 2 minutes.
Plug in the printer. If same error message. Remove cartridge and reinstall. Make sure no clear tape is left on cartridge contact face.
Jul 11, 2012 | HP Officejet 4355 All-In-One InkJet...
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
My printer keeps on saying cartridge error
hi my friend
Jul 22, 2010 | HP Officejet 5610 All-In-One InkJet...
My cartridge alignment keeps failing. what can this be? Keeps saying right cartridge error.
Probably the black cartridge is overheating and printer not recognize it.Replace it and try again.
Oct 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Error keeps popping up saying : cartridge jam
Remove the toner cartridge(s) and check for proper installation. Also check that all shipping tape was removed from the cartridge. I've also seen a more technical issue with there where the gear that operates the cartridge is broken.
Apr 08, 2009 | HP Office Equipment & Supplies
My printer says E 5
Try reseating the ink cartridges. The error references to either reseating or refilling the ink cartridges.
Since you have mentioned that it worked before with only black cartridge, try reseating both and check.
Apr 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Installed new cartridges; keep getting error message
I'd say your using dodgy aftermarket or non HP cartridges, you could put your old ones in and see if message goes away, if having problem when using with Original HP cartridges post back and I'll did deeper for you.
I dont work for HP, I do know printers :-)
Dec 28, 2007 | HP Deskjet 5440 InkJet Photo Printer
HP LaserJet 4300 Printer Logo
321 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
