I was running a small load of wash when the washing machine suddenly stopped. There were no strange sounds or smells prior to the washer quitting. It won't start again, no matter what position I put the dial in. Also, I heard no sounds (as if the machine wanted to start) when I rotated the knob to different positions. I tested the plug in other working outlets. Any ideas?
  • Washing Mach... Master
  • 17,130 Answers
It is important to check if the power is coming into the set and to the timer multicontrol switch. It is not poassible for the switch to fail all oof a sudded unless someone had tried to do it the wrong way or tampered or used violently. If so the switch could be defective.
If will be good to check if teh timer action is ticking when you set to the mode, if not the switch is faulty.Check also the lines to the motor is there is by any chance some rodents have eaten out. Check also teh capacitor to the motor but in this case the motor should make an hum.
I suggest you start with the first parrt and check power to the switch module. Hope this helps. Good day
Posted on Aug 19, 2010
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
There is a moldy smell coming from my washing machine. I have run bleach, lysol, and vinegar throught the washer but nothing seems to alleviate the problem. My husband has also checked under the washing...
I had the same problem once and I had a leak behind the wall, I fixed the leak but still smelled it for a while. I had a small opening in the wall, so I sealed up the hole with that expanding spray filler and it went away
I think the smell is moisture mixed with lint setting on soaked
hope this helps
rick
Jul 15, 2011 | Kenmore 24032\24036 Top Load Washer
I have a 14 year old Whirlpool washer. Yesterday my wife was doing a load. She heard the machine had stopped so she went down to the basement to throw the clothes into the dryer. She smelled a strange...
Most washing machine pumps are mechanical and would leak if bad. I don't think the smell is from the pump... more likely the motor.
Probably best to put the repair money towards a new washer unless you do the work yourself.
Jan 03, 2011 | Whirlpool Washing Machines
Error code 3E Maytag washer
it overheated... turn it off, wait 10 minutes and take out some clothes
Aug 31, 2009 | Maytag MAH6500 Neptune Front Loading...
Kenmore Series 70 Washer stopped working
I can't remember the wiring diagram for this model....but I would check the lid switch first. Lmk if that's it....otherwise you may have to dig in with a meter.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Machine won't wash or spin and won't complete the cycle.
SOUNDS like the motor turning bad , if you hear humming and a strange smell ? yes, you might be needing a new main motor, if you can take a look inside while the machine is ON , check the belt to see if not broken , hope this helpful AJ
May 12, 2008 | Washing Machines
Washer won't spin anymore
Was it getting loud in spin prior to this?
If so, based on past experience with this model, I would say you need at least a triple lip seal, belt and possibly a transmission.
Nov 22, 2007 | Maytag SAV2655A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
