Question about Behringer EUROPOWER EP2500 Amplifier
I bought a mixer with this model "Behringer XENYX 1204USB 12 Ch USB Mixer". And i'm planning to have a set-up of 2 electric-acoustic guitars and 3 microphone vocals. What would be the best wattage of powered amplifier for this setup using the said mixer? Also, what would be the best wattage of speakers that will best suit for this set-up?(i'm planning to use two 15" speakers, and most of my speakers here are 8 ohms). Thanks you!
  • 979 Answers
Hello Sir, Hi, the amplifier best suited for it would be a Behringer also, the EP2500 would be a match, and the eurolive B815neo speakers, but this cost a lot, any amplifier and a corresponding speaker will do. for your electric guitars or acoustics the GTX30. If you will use your 15" speakers, match it with a right amplifier, you did not mention its watts rating, If your speakers are 250 watts, then buy an amplifier slightly higher that 250 watt,
Posted on Aug 19, 2010
Testimonial: "Your feedback info is very helpful to me. Even if you did not discussed it in specific details, giving me some sample models is great. Thanks a lot!!!"
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
Please! show me how to connect an electric acoustic guitar to the mixer
You can't. A mixer won't take the input from a guitar. You would need to connect the guitar to an amplifier and then connect the output from the amp to the mixer.
A mixer is what it is, a device to mix lots of incoming audio signals and mixing the volumes to a number of speakers.
The unit does contain pre-amps, but not to run a device.
http://www.prosoundservice.com/m9/MACKIE-CFX12-mkII--mackie-cfx12-mkii-12-channel-compact-sr-mixer-with-effects.html
Apr 17, 2016 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
How to connect behringer xenyx 1204usb mixer to a numark mixtrack pro II dj controller?
you have to tell your dj or studio program which device to use as output, but the dj controller doesn't have an audiocard so now i first have to search myself since my mixers have built in serato and another that annoying native i. No i'm just doing difficult while a numarkx5 stands in front of me and the main outputs go to your mixer and your usb is just for recording , but plug the mixer out in the mixer , main out in your monitors and calibrate the sound, but your studie or dj gear wants to know which channel to use and there fore you need to read the manual of your mixer and behringer. It's easy, but not from here.
Jul 27, 2014 | Behringer Xenyx 1204USB
Crackle sound
dirty slide switch/rotary pot. clean with contact cleaner or wd40
Feb 20, 2014 | Behringer Xenyx 1204USB USB Mixer
Xenyx 502
You can only do this with a LINE OUT of your amplifier, or HEADPHONE out, as these are line level outputs and will not hurt the inputs of your mixer. Otherwise the signal going to the mixer will be too hot and ruin it. For a Marshall amp,I would prefer to mic it anyway, and run the mic cable to the mixer.
Jun 08, 2013 | Behringer XENYX 502 Premium 5-Input 2-Bus...
Owners manual for Behringer xenyx 1204 USB
Behringer has the documentation for the Xenyx X1204 USB Mixer on the product page: http://www.behringer.com/EN/Products/X1204USB.aspx . See the drop-down menu labeled Documentation on the left side of the page; it's below the list of stores that sell the unit. The owner's manual is at the bottom of the list in that menu.
The file is a PDF so you will need Adobe Reader or a similar program to display the 3.1 MB file.
I hope this helps.
Oct 24, 2012 | Behringer XENYX X1204USB/1204 USB...
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Please kindly rate this solution
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Behringer EUROPOWER EP2500 Amplifier Logo
279 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
