Question about Saniflo & Saniplus& Macerator Pump
Our pump is going continuously. If we stop the motor it stops but then as soon as we switch on again it starts up again. Can you help?
    Scholar:
  • Saniflo Expert
  • 115 Answers
Most likely could be a problem with the float switch. There is a black rubber membrane which water pressure pushes up on hte membrane and activates the pump on and off. Could be something stuck at the bottom of the membrane keeping it on the on position, the membrane could be warped or the micro switch may be stuck on the on position. Depending on the pump model you may have to open up the unit and remove the pressure chamber or inspect the level pressure switch.
Posted on Sep 15, 2010
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Mar 11, 2015 | Aqua Pool & Spa
Engine stars and then stops, not fuel pump problem
What is the make/model/year/motor etc.?
Sep 15, 2012 | Cars & Trucks
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
My water pump stops and starts. the contacts on the pressure switch are closed and voltage is going to the pump. The pump will run for a few minutes but not long enough to reach the 60 # to turn off the...
A lot of these pumps do have automatic thermal switches built into the motor end cap, Double check that its being fed the name plate voltage and that the voltage doesn't drop when the pump is running (which would indicate a loose or bad connection or just undersized wire in the circuit)
Dec 12, 2009 | Plumbing
GE electric dryer (model #DDE5300BBLAD) won't start when I hit the start switch. I do hear a noise when I hit the start switch...stops when I release the switch.
the sound you hear is the motor trying to start.reach in drum and turn clockwise 1 revolution.try to start it again,if it starts your motor is starting to go bad and will have to b e replaced soon.if you canrt turn thje drum you probably have something stuck in blower below lint filter .hope this helps .please rate my response:)
Dec 09, 2009 | GE Dryers
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Saniflo & Saniplus& Macerator Pump  Logo
559 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
