Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
No connectivity from 1 laptop but connectivity with another`
Original laptop works connected to RCA DCM 425. I connected another laptop to same modem port and although NIC card LEDs flash, I can't connect to internet nor receive a default gateway address. What gives?
  • Edward Stewart
    Edward Stewart May 11, 2010
    Have you checked the TCP/IP settings on the laptops do they match, specifically are they configured for static ip or DHCP (automatic configuration)
    What OS are you using on the laptops?
    If you need help checking these items leave a comment and I will walk you through
  • 156 Answers
Try resetting the modem whenever you change between those PC's some NIC's will hang a cable modem stuck on an address.
Posted on May 03, 2008
I have Dlink DCM 202 cable modem. I got thunderstorm one morning and since then my ethernet port in the cable modem is not working. When I connect the modem with USB port, I get internet connection. What...
Did your Internet Service Provider "rent" or "loan" or "sell" the modem to you?
If it is "rent" or "loan", then they will exchange it, if they want to keep you as a PAYING customer.
If they don't, return it to them, and switch to a different Internet Service Provider.
If it is "sell", then they should have included a 1-year or 2-year or 3-year "warranty" on it.
Exercise the WARRANTY to get it repaired/replaced.
Mar 02, 2011 | D-Link (DCM-202) Modem
Can't get Linksys wireless router & RCA DCM 425 to work together
ok, ur old modem was configured for those two devices to work to gether
so u have to do the same here
*have ur modem connected directly to ur comptie
*go to ur command prompt if u have vista ( start * search * type cmd)
xp (run then type cmd)
the type in the screen that poped up ( ipconfig) enter
*look for default gateway type that in ur browser address
*should take u in ur modem interfase go to (advandced | PPPlocation | then set that modem on
BRIDGE MODEM and the modem should restart then connect router that should do it
GOOD LUCK
,July
rate my service please
Apr 11, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Will dcm425 work on playstation 3
Check this thread:
http://www.digitalspy.co.uk/forums/showthread.php?t=555166
Feb 16, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
DCM 425 Modem
check your wap, or wep keys. these can be checked on your wireless connection options or the wireless utily setup
Dec 29, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
260 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
