Question about Avid Media Composer 3 Upgrade Version for PC, Mac
What is error code 43 for AMC 5 on a mac? - Avid Media Composer 3 Upgrade Version for PC, Mac
    Habit-Forming:
    Scholar:
  • Avid Expert
  • 36 Answers
Mac Error Code 43 occurs due to wrong OS Configuration or due to wrong installation. To Fix Mac Error Code 43, just read the easy steps are given below:
Easy Steps to Fix Mac Error Code 43
Step 1: Reset PRAM Settings
    ·First shut down your Mac computer.
    ·Meanwhile Mac is shutting down you need to prepare for pressing command+option+P+R keys all together.
    ·Now turn on your Mac and press command+option+P+R command before the screen with grey start-up appear.
    ·At this point of time hold all these keys until you hear a start-up sound for three times and then release all the keys. Step 2: Delete All Locked Files
    ·You need to navigate to Applications then open utilities and click on terminal.
    ·Now open the terminal and type chflags -R nouchg command on it.
    ·Now find at the bottom dock and double click on the Trash icon.
    ·Press command+A to select all the files in the trash folder.
    ·However, in case of you not able to find the terminal window, arrange finder window, so that you can see at least a part of terminal window.
    ·If you have done then press Return key on the terminal and empty the trash folder.
    After following these steps if you are unable to Fix Mac Error Code 43, then just dial our toll free Mac Technical Support Number 1-833-493-0111 and get instant help.
1 833 493 0111 How to Fix Mac Error Code 43 on Mac OS
Posted on Nov 29, 2017
Display shows E, and will not operate
AMC Error Codes
faq.cncroutershop.com/us/amc-support/amc-error-codes/
Error 5 - The system has detected an E-Stop or hit a limit sensor during the running ...Error 33 - Attempt to run a function 3 on a tool that does not have a Z-axis. ... Error52 - AMC did not receive feedback from the drill indicating that it has fired.
[PDF]Troubleshooting Guide - Sargent and Greenleaf
www.sargentandgreenleaf.com/pdf/Trbl_Shtng_Guide.pdf
Apr 1, 2004 - The Sargent & Greenleaf line of electronic combination locks is not ... safe must be opened by drilling, S&G recommends you contact the safe manufacturer first. ... the safe handle turned fully to the locked position, enter the code .... The lock willoperate with this wire broken, but it will not beep and the LED.
Case IH Troubleshooting Support Information
Dec 15, 2015 | Drills
Time machine on MAC 10.5.8 will not open; error message -43
error -43 fnfErr: File not found
Could be many things, we should start with this...
"Try Disk Utility
1. Insert the Mac OS X Install disc, then restart the computer while holding the C key.
2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu at top of the screen. (In Mac OS X 10.4 or later, you must select your language first.)
*Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.*
3. Click the First Aid tab.
4. Select your Mac OS X volume.
5. Click Repair Disk, (not Repair Permissions). Disk Utility checks and repairs the disk."
http://docs.info.apple.com/article.html?artnum=106214
Then Repair Disk on the external drive.
Then try a Safe Boot, (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it completes.
(Safe boot may stay on the gray radian for a long time, let it go, it's trying to repair the Hard Drive.)
If perchance you can't find your install Disc, at least try it from the Safe Boot part onward.
If TM display doesn't even show up, see this...
http://pondini.org/TM/E4.html
And also i share a link to another error issues.
http://www.macworld.co.uk/feature/mac-software/common-mac-error-messages-3502033/
Thanks,
Mac Support
May 25, 2014 | Computers & Internet
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
A scalene triangle has side measuremnts a=43, b=55, c=30 . Angle a plus Angle b must equal 43. Angle b plus Angle c must equal 55. Angle c plus Angle a must equal 30.
Answer: angle a=9 degree angle b=34 degree angle c=21 degree Explanation: we have, a+b=43............(1) c+b=55..............(2) c+a=30..............(3) from (3) we get, c=30-a...........(4) substituting value of c from (4) in (2) we get, 30-a+b=55.........(5) a+b=43..........(1) (5)-(1) give 30-2a=12 30-12=2a a=18/2=9 degree giving value of 'a' in (1) 9+b=43 b=34 degree similarly giving value of 'a' in (3) c+9=30 c=21 degree
Oct 14, 2012 | TOPICS Entertainment Snap! Geometry...
Cj7 rear
Jeep Axle: AMC 20
Front Axles
Dana 44
Dana 30
Dana 27
Dana 25
Rear Axles
Chrysler 8.25"
Dana 35c
AMC 20
Dana 30
Dana 60
Dana 53
Dana 44
Timken
Dana 41
Dana 23
Jeep Axles
Upgrades
Factory Options
General
-->All AMC 20s have a 8 7/8" R&P and use a 29 spline shafts. The AMC 20 R&P is 3/8" bigger than the Dana 44, but it uses smaller shafts, smaller axle tubes, and the CJ version comes with weaker two piece shafts. The AMC20 uses a 29 spline shaft where as the later Dana 44 uses a 30 spline shaft. The AMC 20 housing tends to flex a lot which can cause breakage. This can be remedied by welding the tubes and/or adding gussets. The reason the AMC 20 flexes more than the Dana 44 is the shorter differential housing and smaller axle tubes. It's other flaw is the CJ version uses the two piece axle made up of a hub and a shaft. The hub end tends to break off under load which has created the market for one piece AMC 20 axle shafts. Unfortunately, the shafts are expensive ($350+ USD) and in some cases a special bearing must be used.
amc20co_.gif -->Identifying the gear ratio of an AMC 20 is a bit tricky. Dana axles normally have a tag on the left of the diff cover with the gear ratio at the time of build. The AMC axles have a code that has to be looked up in a table. The code is stamped on the housing boss to the left of the diff cover right near the axle tube. Good part about the stamp is it tends to stay readable longer than the tag, but you have to know the code. Since there are conflicts between what a code means for a narrow track and what it means for a wide track, don't count solely on the code to identify an axle. Bring a tape measure or know the source of the part. Specs Narrow Track AMC 20 Code Gear Ratio Diff Type AA 2.73 Open DD 2.73 Trac-Lok BB 3.31 Open CC 3.31 Trac-Lok A 3.54 Open N 3.54 Trac-Lok GG 3.73 Open Q 3.73 Trac-Lok L 4.10 Open M 4.10 Trac-Lok Wide Track AMC 20 Code Gear Ratio Diff Type D 2.73 Open DD 2.73 Trac-Lok B 3.31 Open BB 3.31 Trac-Lok A 3.54 Open AA 3.54 Trac-Lok H 3.73 Open HH 3.73 Trac-Lok C 4.10 Open CC 4.10 Trac-LokThe Trac-Lok is a limited slip differential. You may have to scrape away a lot of mud, paint, and rust to uncover the code. If you can't find the code on the rear, check the tag on the front axle. Both axles should be geared the same. The R&P ratio ranges supported by the carriers are 2.73 and 3.31-5.13. The 5.13 gear ratio is not available for the Dana 30 though, so it is rare to see it. 4.56s are the lowest common ratio between the Dana 30 and AMC 20. 5.13s are available for the Dana 44.
CJ AMC 20 The CJs used two versions of the AMC 20, the narrow track from '76-'81 and the wide track from '82-'86. Both versions use keyed, two piece shaft/hub design and 5 on 5.5" wheel bolt pattern. Supplies of AMC 20s were exhausted in 1986 and some Dana 44s were used instead in the last of the CJ-7s.
From 1976-1978 a larger 11x2" drum brakes was used on the AMC 20. After 1978, a 10x1.75" drum was used.
SJ AMC 20 The Wagoneer and full size Cherokee also used a narrow and wide track version of the AMC 20. Both SJ versions used once piece shafts and 6 on 5.5" wheel bolt pattern. Since the length and bolt pattern is different from the CJ version, the SJ shafts are not compatible without resplining and redrilling. I've never heard of anyone going to the trouble.
Model/Version Spring Pads Wheel to Wheel Years AMC 20/CJ Narrow Track 36" 50.5" '76-'81 AMC 20/CJ Wide Track 36" 54.5" '82-'86 AMC 20/SJ Narrow Track AMC 20/SJ Wide Track Last modified Friday, 03-Dec-1999 21:48:34 MST
[ Jeep Tech Main Page | Terry's Jeep Page ]
Copyright © 2001, 2000, 1999, 1998 JEEPTECH.COM
All Rights Reserved, All content with exception of private works and
corporate trademarked logos are property of Jeeptech.com
Jun 06, 2009 | 1985 Jeep CJ7
Deleting
Error -43 is the common "File Not Found" error.  This can also mean a folder is not found. (A Google search for "macintosh error codes" returns a complete list from Apple at http://support.apple.com/kb/HT1618.)  I don't know why it would say this unless the files really don't exist.
Dragging an item to the Trash doesn't usually require a password unless you are not the owner of the item.  This can occur when copying items from another user's account, for example.
Try selecting all of the items that you want to delete, hold down the Option key, and choose Show Inspector from the File menu.  In the Sharing & Permissions area at the bottom of the Inspector window, verify that you have permission to delete the files.  If not, click the lock icon, type an administrator's username and password, then change the Privilege to Read & Write (you might have to use the + icon to add yourself to the list before changing anything).
Close the Inspector window and delete the items.  This should do the trick.
Feb 25, 2009 | Apple Mac 10.5.1 Desktop
Quark for mac
Just downsave the document and it would take care of the issue as well
Jul 13, 2008 | QuarkXPress 4.1 for mac
Avid Media Composer 3 Upgrade Version for PC, Mac  Logo
96 people viewed this question
Top Avid Computers & Internet Experts
Michael Galve
Michael Galve
castletech
castletech
Are you an Avid Computer and Internet Expert? Answer questions, earn points and help others
