Televison & Video Logo
Posted on Aug 19, 2010
How do i change the input on my sanyo vizon tv without a remote
5 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Feb 23, 2007
SOURCE: How do I change the input without the remote
If there is no nutton on the TV to do so then you have to have the remote for it. You can try a universal remote but, usually functions like that don't work. Here is a link to the remote you need. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6450348129
A
Anonymous
  • Posted on Jul 20, 2008
SOURCE: sanyo vizon dp42746 problem
me too i bought mine like 11/2 years ago
Anonymous
  • Posted on Jan 20, 2009
SOURCE: Lost the remote & Sanyo Vizon is stuck on a "D" screen
If you use a tv dish or cable box you could program the cable or dish remote to control your tv. Look up the codes online
Anonymous
  • Posted on Nov 28, 2009
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
geek2010
  • 100 Answers
  • Posted on Sep 28, 2010
SOURCE: Lost remote to tv and
Contact the manufacturer? They may have a lead for you.
How to reset the TV menu on my sanyo vizon 24k40?i think a menu pop out and someone in the house mess it up?can't access the whole menu and remote control isn't working?
Hold down "INPUT" Button at TV panel, while you press "INFO/A-B" button in your remote.. Or...Hold down "INPUT" Button at TV panel, while you press No.1 chnl on your remote..
How does one program the remote on the sanyo vizon tv without the manual
Hello
It will be very difficult to programme and do other adjustments with this set, whthout having its user manual. You can download if free from the following link. If you feel any difficulty in downloading the same, send your email address to me by Fixya. I've the user manual of your Tv, and I'' send you a copy of it by return mail. OK
www.retrevo.com > Sanyo Manuals > Sanyo TV Manuals
20 SANYO VIZON DOES NOT HAVE MENU BUTTON IN THE TV
The menu button is on your remote control, it is located at the bottom of the input button
2answers
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
How to connect?no instructions
ok maybe this will help.
make sure the video and audio are in the right place... setup:
  O OOX yellow OOX white OOX red OOO OOO
then turn device on (dvd/vcr) and on the remote press input button at the very top. this would set your device to video one screen, and you can watch whatever it is that you hooked up.
for cable or antenna hook that up then press reset button on remote ( bottom right hand side)
2answers
Changing program source without remote
Do a web search for a replacement remote control. If you got the tv without a remote, then I'm guessing you don't have a manual either. Here's a link to a free downloadable manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e341b6ad1733d53ba32cb47caf24d013&q=Sanyo+DS19330
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
