Question about Hayward 1.5 Hp Northstar High Performance Pump
I have a Hayward Northstar 1hp pump and one day I heard it humming I read about took the pum apart and cleaned it up put it back together and it started working but two hours later it stopped againg and tripped the switch. What can i check now ??
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up again but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 19, 2010
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot....
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
May 08, 2014 | Hayward Pool Products Hayward Northstar...
Hayward 1hp super pump-self priming -rebuilt won't run
something is binding take apart and try again
Jul 30, 2013 | Hayward Pool & Spa
I have a NorthStar pump. The motor went out so I have it replaced with a different manufactured motor (WEG). Same HP and even a higher SF factor than the original. The new motor draws 10 amps (rated is...
THATS WHAT YA GOT 2 DO ..SOUNDS LIKE YOU HAVE THE WRONG MOTOR .9.6amps IS A 1 1/2 HP ... A 1HP IS 7.6amps.. SO A QUICK FIX WOULD TO GET A 3/4 HP IMPELLER , THAT WILL GET YOU BACK IN THE NEEDED HP RANGE .. welcome to the HAYWARD NORTHSTAR .. HEY IF'N I WAS ANY HELP COMMENT OR VOTE ..JAY
Aug 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Jul 15, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
My Hayward pool pump was humming, but I got it running. Now it is not pulling water into the filter. Does anyone know what the problem could be?
WELCOME TO THE DREADED NORTHSTAR..THEY FAILED TO PUT A LOCKING SCREW ON THE IMPELLERS ON THESE WITH A MOTOR THAT CAN RUN IN REVERSE ON A WHIM . SO WHAT ITS DONE IS MUCKED UP THE THREADS ON THE IMPELLER.. YOU WILL FIND THAT THIS IS THE HARDEST PUMP TO WORK ON ! PARTS $$$ CRAZY .. I SEE A NEW PUMP IN YOUR FUTURE ,, A STA-RITE DURA GLASS !....; WHEN GETTING A NEW PUMP TELL THE THE HP AND SF SERVICE FACTOR OF THE HAYWARD YOU HAVE SO YOU GET THE RIGHT SIZE PUMP FOR YOUR NEEDS ..GOOD LUCK AND VOTE FOR ME...JAY
Jun 13, 2010 | Hayward Northstar Pool Pump 2 Hp Sp4020ns
My hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Sep 29, 2009 | Hayward 1.5 Hp Northstar High Performance...
Northstar 1.5 hp pump motor is always hot and shuts off for ten minutes aned comes back on. The voltage and amperage is good. What's the problem
It has an internal thermal overload protection device that is turning it off. Once it cools enough it will automatically turn back on as long as whatever switch or timer you have controlling the pump is in the on position. If you are certain it is not due to a voltage or load condition then it would seem the only other problem is mechanical.
In any case try a local electric motor repair shop.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 1.5 Hp Northstar High Performance Pump Logo
99 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
