Question about Whirlpool Dishwashers
My whirlpool dishwasher stops midcycle and the "clean" light blinks. Please help
  • Whirlpool Master
  • 12,061 Answers
Http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
Hi your problem is addressed extensively and comprehensively at this website above.. Enjoy..
Posted on Aug 19, 2010
Whirlpool gold gu180esjs. start light blinking won't go through cycle, keeps stopping. tried killing the power and restarting, filter is clean, no obstructions. no helpful info online for this model....
Remove the bottom kick plate. There you should find the Whirlpool factory technical data sheet. This sheet will guide you through the diagnostic process.
Mar 25, 2015 | Whirlpool Dishwashers
Dishwasher stopped midcycle and the fuse is not tripped
Some dishwashers work the wire nuts loose in the connection box. Especially those that
are wired to aluminum wiring (these require the purple "IDEAL" brand wire nuts).
Make sure to secure power to unit before servicing.
Mar 06, 2011 | Whirlpool Gold GU2475XTV Builtin...
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The clean light is blinking on the dishwasher. i
if its flashing 7 times. make sure hot water 120degree goes in unit. if water is satisfied then replace heater and main board. its a kit
Feb 09, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool dishwasher stops midcycle and control panel goes blank
and the controls dont advance? to the end of cycle?
Feb 26, 2009 | Dishwashers
Dw stopped in midcycle.
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
May 31, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Clean light flashing
Here is the solution to your problem. Push in this order, High temp, heat dry, high temp, heat dry, all the lights will begin to blink. After they stop, the dishwasher will start. Press cancel twice.
May 06, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
351 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
