Question about GE JVM1750SMSS Microwave Oven
Microwave has power but will not heat anything. Has worked fine until now.
  • GE Master
  • 17,130 Answers
If you have noticed that the cabin door is lit and the table turns, then the possibility of the power board working is a good sign.
You will have to open the covers after removing the power. Inside is located the magnetron fitted on the side of the outside cabon to radiate into the inner cabin. There is a high voltage that is necessarry to activate the magnetron. If this voltage is absent( must have a HT tester to confirm) please check the power capacitor for fault. You can test the capacitor and change if faulty.
Please also check when the relay click if the contacts give supply to the magnetron.
I hope you take care and precaution of high voltage/ radiation when the magnetron is on.
Hope my advice helps. please comment. Good day
Posted on Aug 19, 2010
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
My kenomore Microwave has pwer and has stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
0ut
Dec 26, 2008 | Kenmore 63793 Convection / Microwave Oven
Microwave won't heat anything
take the cover off the machine and look for a 13amp fuse that supplys the tranformers. BEWARE!!!
when you open the machine disconnect from the mains and do not touch the high power circuits the capacitors can hold a charge that can kill.
Jul 06, 2008 | GE JES1142SF Microwave Oven
Microwave will not heat
If all controls on the panel work fine but the microwave does not heat, then either you have a defective door switch,the smartboard is defective, or you have a defective magnatron.Most likely one of those three.
Nov 06, 2007 | Magic Chef CMV1000B Microwave Oven
GE JVM1750SMSS Microwave Oven Logo
65 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
