Question about Amana ACS3350AS Gas Kitchen Range
All four burners of my Amana ACS3350AS range stopped lighting today. The covers are in the correct position and no debris is blocking the electrodes, they simply stopped lighting. The power is on, gas flows and I can light the range manually. Also, the oven still ignites and cooks well. Any assistance would be appreciated.
    Genius:
  • 1,417 Answers
what this indicate from your statement could be view from two ways ,that is the problem can check and solve from two way .
1 from the fuse or,
2.from the wire connections
what you are to do to solve this problem first of all put off all form of power supply connected to the range ,then carefully unscrew the screw use as key on the range with technician tools either screw driver or allenkey depending on the nature of screw use on the range then trace the wire down to the fuse at the back of the range
Locate the fuse. It should be near where the electrical cord comes into the range. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the range.
Purchase a new fuse. Most range ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
Replace the fuse. Put the cover back on and see if your range works. If it does, replace the screws. If it does not, try a different fuse. If the microwave still does not turn on, you may have to have it replaced of professionally repaired.
but for the wire connection carefully trace the wire down to the element it is silver in colour see if there is any form of loose wire connected to the element carefully replace the wire on the element then couple it back to is position with this the problem of the range will be solve .
thank you.
Posted on Aug 19, 2010
All four burners and stove just stopped getting hot amana electric stove
If all burners and oven no longer heat, you don't have 240volts supplies to the oven any more. Could be wire burnt off terminal block where the cord attached or could be that your household electrical has a problem.
Jun 02, 2014 | Kenmore 95002 / 95004 Electric Kitchen...
I have an Amana ACS3350AS Gas range and the Control panel cover has cracked due to heat.After much searching on the web I found a replacement but I can't seam to find any manuals on how to dismantle it...
hello, this unit should only have screws under the control panel when you open the oven door. some of them have a side screw on each side when you pull out the oven an inch or two. hope this helps
Jun 08, 2011 | Amana ACS3350AS Gas Kitchen Range
Electric range amana model number AER5515QAW right rear burner repaired 2 times by sears still broke again is the it defected wireing? how do i fix it
It sounds like the Sear's repair person should be looking at the amperage while the burner is in operation...there seems to be an higher output at sometimes.
Oct 27, 2009 | Amana ACS3350AS Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
My Amana ACS335AS oven works sporadically.
the amana ACS3350AS control panel is broken, I need to replace it, where can I find it?
Jan 29, 2008 | Amana ACS3350AS Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
154 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
