Manual for denmark audio da 750 - Audio Players & Recorders
I need the manual for TDK DA -5900 4x Digitakl audio CD receiver
Asking the question a thousand times won't get a faster answer but a Google search will.
You'll have to register for free to get it here.
http://www.hifiengine.com/manuals/tdk/da-5900.shtml
Jul 19, 2011 | TDK DA-5900 2-Disc CD Recorder
HOW DO I RECORD FROM A MD PLAYER TO THE TDK DA-3826
As described in the manual, like any other digital source.
Find a link to it here...
Click on "Get This Manual"
http://audio.manualsonline.com/ex/thread/view/idThread/1858792
Feb 05, 2011 | TDK DA-3826 2-Disc CD Recorder
I need a copy of my tdk da-3826 owners manual. serial number is 011kh14368
Serial numbers are SO irrelevant. Model numbers, yeah.
Oct 10, 2010 | TDK DA-3826 2-Disc CD Recorder
Problems with timing the camshafts for a VF 750 Interceptor . It is the two front cylinders problem. The engine works, but not good. When running it is blowing out back of the two carburators.. i have a...
The cam timing is pretty straight forward: with the #1 cylinder at top dead center, the timing marks on the cam sprockets should be level with the valve cover gasket surface.
I can't imagine the engine would run at all if the cam timing were off, my suspicion is that the intake valves on the two forward cylinders are bent (explaining the blow-back through the carburetors). This can occur if the crankshaft is rotated without first having the cam timing set correctly.
Nov 17, 2009 | 1984 Honda VF 750 S
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
Aug 02, 2009 | PPI DCX-1500.1 Car Audio Amplifier
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
No audio
Select the analogue source input.
Jan 12, 2008 | TDK DA-3826 2-Disc CD Recorder
230 people viewed this question
 Grubhead
Grubhead
