Question about HP vs19 (Silver) 19" LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
  • 105 Answers
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Posted on Aug 21, 2010
Testimonial: "Thank you, problem fixed."
    New Friend:
The monitor just plugged to the wall keeps check video cable
Posted on Jun 25, 2013
The display of my monitor (hp w1907) is widened. A circle looks like an elipse. How can i solve this. please help.
It might tvhat there are no video drivers on the PC or there screen resolution is too big or too low
Screen Resolution Issue
Windows XP
1. Click Start -> Control Panel -> Display
2. Display Properties should appear
3. Click on the Settings Tab
4. Slide the Bar to the Left or to the right Making the picture almost a square
Windows Vista/ Windows 7
1. Click Start -> Control Panel -> Personalization
2. Click on Screen Resolution
3. Move the bar up or down until the picture turns almost a square
Or else reinstall a new video driver configure the screen resolution again
Hope this helps
May 24, 2011 | HP w1907 LCD Monitor
HP LE1901w -- monitor starts then goes into sleep mode
welcome my friends ,, all about football here !
http://www.news-football.org/ Football News
diego goals vs barcelone ! here ! Football News
Apr 24, 2010 | HP w1907 LCD Monitor
My monitor will come on during start up of computer then it goes to sleep and stays black. Can you help?
please check the resolution setting of your windows
if u canot go to windows please try to enter through safe mode
and go to device manager and go to display and right click on the adaptor and uninstall it and resart the windows it should be fine
Apr 18, 2010 | HP w1907 LCD Monitor
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
Mar 13, 2010 | HP w1907 LCD Monitor
My hp w1907 monitor goes dim after start up. It
More likely to have problem in the power supply, back light inverter circuits, or worst will be bad lamps. Look for bad caps with bulging top first, post back what you see so we can guide you further, see example of failed monitors mostly due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | HP w1907 LCD Monitor
My monitor goes to sleep and doesn't come back on.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
Feb 07, 2010 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Computer asleep
If you go to control panel > display settings > Screen Saver > Power (win XP) or Control Panel > Power Settings (Vista).
This will allow you to turn off the sleep or change the amount of time until the computer goes to sleep or turns the monitor off.
Mar 26, 2009 | HP w1907 LCD Monitor
Hi, I have a compaq deskpro that is working fine however, the monitor is having trouble. I took the monitor to the shop and it is fine also. Likewise, I placed a monitor from another computer onto the...
The monitor setting in windows maybe incorrect. When booting up before you get the windows logo start hitting F8 and then choose safe mode. If your monitor works in windows there then check the monitors settings. You may have a driver issue or a settings issue when in normal windows mode.
Jul 07, 2008 | Compaq Computers & Internet
Sceptre D50X black screen
If a monitor shows a normal screen at startup but goes bad after the Windows logo disappears, your Windows video setting is probably not compatible with the monitor. You can start Windows in safe mode to select a compatible resolution for your monitor.
Aug 16, 2006 | Sceptre Dragon Eye D50X (White) 15 in.CRT...
HP vs19 (Silver) 19" LCD Monitor Logo
557 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
