Question about HP Computers & Internet
HP iiip printer doesn't feed paper. Goes through all the motions. WHY?
  • ajolson Aug 20, 2010
    Sorry no work. Did the 07 reset as you said. The paper just doen't feed in. I checked the print rollers, etc and they look OK. If I force the paper way in it does draw it through when I ALT FORM FEED Paper should automaticly feed in. Help Is my paper too thick? I've printed Christmas letters with much heavier paper last year.
    What does the subject barcode scanner have to do with this problem. HP iiip feed issue?
  • HP Master
  • 4,924 Answers
Try to reset it first by holding down the alt ..and press the reset until the 07 reset message appears ..
If this do not have any effect ..verify the rollers and the print head to be in place and also the front door (lit)to be proper closed so that it do not be in the service mode...
Posted on Aug 19, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Aug 20, 2010
    it might be an issue caused by the thicker paper...and now it cannot grab the normal one ...probably the rollers are slightly broad apart ..take a look and see if they have any adjustment mechanism or something ..also you may use some thicker paper if nothing else will work ..
    and about the last question ..this is your fault that the question got into the bar-code area...cause you posted it so ....:P
    I noticed 52 error. What does that mean? Other codes appeared prior to E52. Such as EadyLeft. I don't see any adjustments on the rollers 52 Letter appears when it tries to p;rint. Just doesn't feed the paper.
  • Catalin Turcu
    If you should have said that from the first I could had say that the problem for not picking up the the paper it is from the laser motor that failed ...
    http://www.fixyourownprinter.com/kits/hp...
    here are some details about that ..
    and the possibility to get what you need to fix it ..
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
Paper jamming only takes card stock however does not print anythi
I would replace the printer if it was giving me that much trouble.
May 11, 2017 | HP LaserJet IIIp Printer
Paper does not feed through, gets crumpled, jams
you have to remove all covers, then you have to clean all paper feed rollers..chek fuser assy too! If you unable to do that just go visit any special printer service!
Apr 05, 2010 | HP LaserJet IIIp Printer
How do i get my printer to pick up the paper to run and print through
Clean all the rollers with a very damp cotton pad or cloth with a little dab of dish washing detergent,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 19, 2008 | HP DeskJet 5550 InkJet Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
