Question about Frigidaire Dryers
My dryer squeels a high pitch sound until it heats up. it does ok till it starts cooling down then it squeels again. Is it the drum bearings and how hard are they to replace? It is a frigidaire Gallery heavy duty stacking unit. Model # FLSE72GCS
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Aug 20, 2010
Clothes Dryer makes high pitched sqeak
Most driers have to be disassembled from the back and work your way forward. Try that.
Feb 03, 2014 | GE DCVH480EKWW 4.0 cu ft electric dryer
Renault Kangoo 1900 diesel van squeeling over 26 mph but ok if i hold the same speed.
suspected clutch throw out bearing
failing
pressing on the clutch pedal loads up the bearing and the noise stops but removing the foot from the peddle allows the the pressure plate fingers to spin a loose bearing race ans so makes the noise
Mar 16, 2017 | Cars & Trucks
Has anyone thought it might be the clutch release bearing? This is of course inside the bell housing, between the engine and transmission.
For a long time before the bearing goes completely out and need replacing, it could start squealing like that. It is a sealed bearing, but when old the internal grease may dissipate, and cause squealing.
Mar 14, 2017 | Cars & Trucks
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My dryer is making a high pitch squeeling noise like metal on metal and it starts jumping around hard. please help
You need the rear drum bearing replaced,and while tearing down to replace the rear bearing the front bearing surface should be inspected (Its actually a plastic piece with teflon glide bars attached that the front of the drum rides on)..
Sep 18, 2010 | General Electric Dryers
DRYER SQUEAKS DRYER HAS A HIGH PITCH SQUEEL WHEN TURNING
That is caused by lack of lubrication of the REAR bearing for the drum. It will have to be removed and grease will need to be added. If the machine is run without this, a new bearing will have to be purchased. If the squeeling just started, the bearing is ok - you just have to get the job done very soon. While in there, they should clean the lint out. They should also lube the idler pulley for the belt. The idler pulley is often forgotten, and this item should be lubed every time the machine is serviced. Good luck.
Apr 28, 2010 | GE Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
Dryers Logo
356 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
