Question about Magic Chef 31000 Gas Kitchen Range
Igniter is self igniting and will not stop we are concerned to go to bed as it we are unable to shut it off please help asap thank you
    Brigadier General:
  • 3,513 Answers
More than likely you got water in the switch assembly. If you turn it on for a while and let it warm up the moisture might evaporate. When it cools down it should be fine. If not just wait and see if it will dry on its own. You could turn the power off for a while so it will stop until it drys out.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Posted on Aug 19, 2010
WE SHUT OFF THE GAS TO THIS STOVE SEVERAL WEEKS AGO AND ARE READY TO RELIGHT THE STOVE NOW. WE CAN NOT FIND THE MANUAL AS TO HOW TO DO THAT. WE ARE CONCERNED MAINLY ABOUT THE OVEN AS IT SAYS IT IS A...
You should be able to just open the gas ****. That will supply gas to the gas to the stove. Once you've opened the gas ****, wait about 60 seconds and turn on one of the burners. The electric ignition should work to ignite the gas and you'll have your flame. If you smell a strong odor of gas, DO NOT use the electric ignition until the gas odor diminishes. In other words, when you first smell gas, you can try lighting it. If the smell of gas becomes strong, you DO NOT want to light anything in the area because an accumulation of gas can lead to an explosion. Be very careful.
If this helps, please come back to Fixya and rate my suggestion.
Jun 10, 2011 | Kitchen Ranges
Ignition swith short. computer has shut down.
Can you please explain more indetail about your concern.
Did you mean to say " ignition SWITCH shorted, computer has shut down ?
Please check thr following, check your fuses and make sure they are all good, there are also fusues under your hood in a black plastic case marked " FUSES"
There you will find fuses and relays.
I quess my biggest question is why did the system short out ?
Please relay back to me what you have found, on your 2006 Chevy trailblazer, with which engine ?
Feb 06, 2010 | 2006 Chevrolet Trailblazer
Heater displays everything but you cannot turn anything on ac will not turn on neither will the heat the buttons will not even light up please help
From the equipment description, I take this to be a EATC ( Electronic Automatic Temperature Control ) system.
You can try to run the EATC diagnostic test & recalibrate ( once you have confirmed it is not a fuse )
Electronic Automatic Temperature Control Module On-Demand Self-Test The EATC module on-demand self-test will retrieve on-demand (hard fault) DTCs only, it will not retrieve continuous DTCs. Continuous DTCs can be cleared when exiting the EATC module on-demand self-test. Make sure to retrieve continuous DTCs by carrying out the Electronic Automatic Temperature Control Module - Retrieve Continuous DTCs procedure before clearing any continuous DTCs.
•The EATC module on-demand self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
•The EATC module on-demand self-test will detect concerns in the system control functions and will display on-demand (hard fault) DTCs for concerns that are present during the self-test. The vehicle interior temperature should be between 4°-38°C (40°-100°F) when performing the self-test. If the temperatures are not within the specified ranges, false DTCs may be displayed.
•The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
•To enter the self-test, press the OFF and DEFROST buttons simultaneously and release, then press the AUTO button within 2 seconds . The display will show a flashing blower icon for 20 seconds , after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present the EATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
•If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit the self-test and retain all DTCs, press any button except DEFROST. The EATC module will exit the self-test and retain all DTCs.
•To exit the self-test and clear all DTCs, press the DEFROST button. The EATC module will exit the self-test and all DTCs will be cleared.
•Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
•Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
The EATC module will retrieve only continuous (intermittent and hard) DTCs when carrying out this procedure.
•Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
•To retrieve continuous DTCs, press the OFF and DEFROST buttons simultaneously and release, then press the RECIRC button within 2 seconds . All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (°C) on the EATC module display. Record all DTCs displayed.
•If any DTCs appear, carry out the diagnostic procedure. Refer to the Electronic Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given. See: Diagnostic Trouble Code Descriptions
•If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Incorrect Operation. See: Symptom Related Diagnostic Procedures
•To exit and retain all continuous DTCs, press any button except DEFROST. The EATC module will exit the retrieved continuous DTCs mode and retain all continuous DTCs.
•To exit and clear all continuous DTCs, press the DEFROST button. The EATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
•Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited, the ignition switch must remain ON for at least 30 seconds to allow the door actuators to automatically recalibrate.
Electronic Automatic Temperature Control (EATC) Module and Electronic Manual Temperature Control (EMTC) Module Cold Boot Process The purpose of the cold boot process is to allow the EATC or EMTC module to re-initialize and calibrate the door actuators. To carry out the cold boot process, follow the steps below.
1.Turn the ignition switch to the OFF position.
2.Disconnect the EATC or EMTC module electrical connectors.
3.Wait one minute .
4.Connect the EATC or EMTC module electrical connectors.
5.Turn the ignition switch to the ON position.
6.Select any position except OFF on the EATC or EMTC module. The EATC or EMTC module will now initialize and calibrate the mode doors. Calibration of the mode doors will take approximately 30 seconds .
Nov 27, 2009 | 2005 Ford F-150
My chevy cavalier 2000 has a theft system light on and it wont start
Put key in ignition, turn to on (do not start) position for exactly 10 minutes. As SOON as the light turns off, start car.
This is a problem with most gm vehicles. The vault is the computer.
Jun 30, 2009 | 1998 Chevrolet Cavalier
Smoke from steering column
There is a short inside th steering column that concerns the multi function switch and ignition assembly that should be inspected asap. this could cause a fire so, i would get this looked at or repaired very soon.
Suggested repair is to re wire the entire column asap.
Jun 02, 2009 | 1993 Oldsmobile Cutlass Supreme
Smelling fumes from 4xl55. Also cycles many times b4 igniting.
Hi jim if you are smelling fumes turn it off and get a service done on it asap
Mar 27, 2009 | Dayton Gas Furnace Heater
Assembly Instructions Durham Cot Bed
Have attached a copy of my instructions
Mar 10, 2009 | Baby Gear
Oven burner
hi thanks for the question. you saw the element burn its self out . its burnt out know don't worry go to bed . replace the element tomorrow . thanks the appliance doc
Jul 03, 2008 | GE Profile JTP18 Electric Single Oven
Magic Chef 31000 Gas Kitchen Range Logo
37 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
