Question about Sony PlayStation 2 Slimline Console
I have the ps2 slim model scph-79001 and its not reading god of war and god of war 2 BUT it can read other games! How do i fix it so it can read the two games i just bought NEW?
4 Suggested Answers
Jmizpah777
  • 290 Answers
SOURCE: God of War 1 and 2(Unable to read disc)!
Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
probably your game console has problems on disk reading.
FIX Those Ps2 disk errors.
You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
well. i hope this works.
pm me if problems continue.
Posted on Aug 08, 2009
danakeith
  • 16 Answers
SOURCE: god of war wont work on my scph 75001 black slim ps2
the disk itself might be corrupted
Posted on Jul 04, 2010
  • 11 Answers
SOURCE: my ps2 slim wont read
God of War II being one of the few Dual-Layer discs on the PS2, it is possible that your problem originates from your PS2 lens being unable to read it correctly. The PS2 Slim is supposed to be able to read Dual-Layer, thus you should try cleaning your lens, it may be dirty, leading to this kind of error while still able to read Single-Layer discs.
-Organicbeing
Posted on May 15, 2011
My ps2 slim wont read god of war II disc but it reads all my other games just fine so please i need a solution
-Organicbeing
May 14, 2011 | Sony PlayStation 2 (PS2) Console
I bought 2 new God of war and God of war II disks but my console, SCPH-75004 fails to read them both. When i returned the discs for exchange however, they play well on the retail console. do you think my...
This is a very common problem with playstation 2's. If you have a newer slim system its fairly simple to open the disc bay and use canned air to dust the lens. If its a thicker older model than theres not really much you can do. you can try a lens cleaner disc, but this rarely works.
Apr 01, 2011 | Sony PlayStation 2 (PS2) Console
Can't play dual layered disk in playstation slim silver
I know, this is very annoying. Mine is SCPH-79001.
Just put in the game like you would any game (that would read) and you should hear a few ticks. Turn the ps2 horizontly with the front facing you. And whenever you hear a tick, just tap it against you knee, then you should hear it spinning.
My ps2 wouldn't read GH world tour or metallica, but know it works. Hope I helped
Jan 21, 2010 | Sony PlayStation 2 (PS2) Console
GUITART HERO METALLICA
I have a ps2 slim SCPH-79001, so I am not sure if it will work with the fat ps2s but:
Turn the ps2 horizontly with the ps2 front facing you. Then put it in, you should hear a few ticks (with the slim) and just tap it against you knee a few times until you jear it spinning.
Again, I'm not sure if this will work with the fat ps2, but I hope I helped.
Dec 26, 2009 | Sony PlayStation 2 (PS2) Console
Guitar hare metallica
When the ps2 is on and the disc is in, so this:
1. Turn the ps2 horizontly
2. When you hear the ticks of the laser trying to read, tap it against your knee until you hear it spin
I'm not sure if this will work with the fat ps2s because I have a silver SCPH-79001 model. Hope I helped
Jun 21, 2009 | Sony PlayStation 2 (PS2) Console
This is a PS2 Slim model SCPH 79001. Reset button does not work. When I plug it in the red LED lights up but when I push the reset button nothing happens.
check the connection, if you have the ps2 plugged in and it wont turn on it would be best to return it or have someone look at it.
Mar 12, 2009 | Sony PlayStation 2 Slimline Console
Unable to read god of war II
Some ps2 models have defective lens coils that wont properly focus the lazer beam on the disc ive had this happen to me before, but to fix it, it requires you to replace the reader head. I can walk you through it, but only if you are comfortable in dissassembling/reassembling the ps2 with the chance of perminately harming your ps2 or yourself. Id advise you to take it to a repair shop for fixing.
Dec 21, 2007 | Sony PlayStation 2 Slimline Console
Ps2 - certain games do not play
It sounds like your console is having trouble reading dvd's which means either the laser is dirty or failing
Aug 30, 2007 | Sony PlayStation 2 (PS2) Console
New game won't play.
the problem with god of war 2 is the ps2 lasers are not capable of reading the dual layer disks. either wait and get a ps3, change the laser - i just bought on for 3 quid on e bay brand new. the lasers are not designed to be played the amount they are played. the laser is designed to play 20 hours a week but as sony found out he avg gamer will clock up up tp 60 hours a week so the lasers are only lasting 1/3rd of the time they should. plus if they put a good laser in the machine u would one buy 1 ps2 and then 1 ps3. i have burned out 3 ps2's so far lol. just forget the game or wait till its put on platinum as these are single layerd disk
Apr 02, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
126 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
