Question about Garmin nuvi 255W GPS Receiver
Hello, My Garmin Nuvi 255W has worked fine, until recently. It loses the satellite signal for no reason and then re-acquires it a few minutes later. It seems to give me some weird directions. What gives?
  • 3,083 Answers
Not sure what's going on with the weird directions, but the loss of the signal could be slightly frayed wires if you have an external antenna. Couple that with the weird directions, and it sounds like it might be a power supply problem, or temperature sensitive component in side the unit. I would try another antenna first. Any further inspection would require opening it up and troubleshooting it. If you use cool spray you can locate the bad component, but finding the replacement part can be next to impossible. Hope it's just the antenna...good luck!
Posted on Aug 19, 2010
My Garmin Nuvi 3790T will not acquire a satellite signal
Does the GPS work outside of the vehicle?
Where is the GPS mounted?
If the GPS is under the dash, mounting it up on top of the dash will help.
If the Vauxhall has a windshield with a reflective metallic coating or treatment in the glass, this may result in poor GPS satellite reception.
Apr 12, 2012 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
My garmin 255w keeps telling me that it's
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Aug 17, 2011 | Garmin nuvi 255W GPS Receiver
I baught a nuvi 255w but the SD card has no data in it, where i can download it cheapest or free please.
The following is the nuMaps Guarantee on page 8 of the nuvi 205W series quick start manual that would have come enclosed in the packaging of your recently bought nuvi 255W...
nuMaps Guarantee
To receive one free map update, register your nuvi at http:/my.garmin.com within 60 days of acquiring satellites. For more information, go to www.garmin.com/numaps
Apr 11, 2011 | Garmin nuvi 255W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Garmin GPS acquiring satellite Issue
I would return it to Garmin for service.
Mar 23, 2017 | Garmin nuvi 200W GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
