Question about Canon Office Equipment & Supplies
MY PIXMA 1000 KEEPS COMING UP INK ABSORBERS OVERFLOW AND THEY ARE DRY. CAN'T GET PRINTER TO WORK
  • 265 Answers
Try to follow this procedure carefully to manually reset your printer's waste ink pad counter ;
1. Turn off the printer. And disconnect the printer cable from the computer.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
Posted on Aug 19, 2010
The ink absorber is almost full on Pixma MP110-how do I clean?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 19, 2013 | Canon PIXMA Office Equipment & Supplies
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
    Reset waste ink tank counter CANON PIXMA iP 1000
    Disconnect printer from AC power
    Press and HOLD the POWER button, and connect printer to AC power
    release the the POWER button
    Press the POWER button again
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
Canon PIXMA ip1980 full ink absorber
This may clear the ink absorber.
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jul 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My ink absorber is full, how do we fix that. Canon pixma mp210 printer. Everytime i want to print that come up.
Jun 09, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
How do I replace the waste ink absorber or keep the printer printing more than 1 document before having to hit resume?
You need a shop to replace the ink absorbers because only Canon shops can use the service mode to reset the counter. If the ink absorber is full and you bypass the errors it will overflow damaging the printer so you need a new one anyway. If the absorber is full it means it's made a ton of prints and needs repair or replacement.
Feb 09, 2010 | Canon PIXMA iP1600 Printer
Pixma ip1880 ink absorber is full pls tell how to fix
Turn off the printer and take some soft absorbent tissues and fold it into a pad.
Lift the cover to expose the ink cartridges and place this pad over the ink absorber on the LHS of the printer so the pad soaks up the wet ink.
Repeat until the absorber is nearly dry.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Power lamp always red. The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber.
You need to have the absorber replaced at a shop where they can reset the count after changing the absorbers, otherwise ink could overflow and make a mess.
Jul 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My pixma MP500 printer prints a black solid line at the back of the sheet. what's the problem
Ink is coming up from the bottom from the purge assembly. The hose that should take the ink to the ink absorber makes a pile of hard ink and it overflows instead of being spread. It needs a good cleaning to get rid of the excess ink and a mylar strip to keep it from happening again. 80 to 100 dollar shop repair unless it's under warranty.
Jun 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
18 people viewed this question
old marine
old marine
