Question about HP Office Equipment & Supplies
Using the HP Photosmart C7200 all-in-one series. Trying to print envelopes #10 from my palm desktop software's contact list. Continue to receive the error "Paper Mismatch ... Paper size or type is incorrect. Press OK to cancel job." I hit OK and it spits out my envelope. have changed default size to #10 envelope, with no luck THanks, Julie
  • 45 Answers
SOURCE: envelopes
Follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03053&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Posted on Oct 04, 2007
  • 4 Answers
SOURCE: Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
  • 4 Answers
SOURCE: HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
SOURCE: cannot print envelope on HP Photomart C6180 All in One
What program are you using? If it's Microsoft Word, are you using the Mailings section, and envelopes?
Posted on Apr 19, 2009
sgoswami
  • 114 Answers
SOURCE: HP Photosmart Premium c309a series will not print
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Posted on Sep 21, 2009
Testimonial: "Still not working. Great idea, tho."
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Oct 09, 2011 | HP Photosmart Premium C309A All-In-One...
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
How to address size #10 envelopes using HP C4280 printer?
Goto print and preferences then under paper size select envelope size 10. Line them up over their picture on the printer and voila. If you are using word there is an envelope creator under the file menu.
Apr 27, 2009 | HP Photosmart C4280 All-in-One InkJet...
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
Print Envelopes on HP Photosmart 7280
This is a paper size problem with the software, go to page setup and under "Paper Size" choose "User Defined" or "Custom" and fill in all of the dimensional information about the envelope and save with a name you will recognize. Now, when you print make sure you have selected the envelope from the paper list and you should be good to go. If you need further assistance, click "Ask Me" and I will answer your request as soon as I can.
Oct 07, 2008 | HP Photosmart C7280 Printer
Prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Aug 01, 2008 | HP Photosmart C7280 Laser Printer
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
