Question about Leupold Yosemite (8x30) Binocular
The central hinge is too loose and the IPD does not remain constant. Can I tighten it myself, and if so, how? Robert
How to tighten loose display hinges on toshiba pro a10
There ares no adjustments to tighten the hinges, they need to be replaced.
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Jul 20, 2012 | Toshiba Satellite Computers & Internet
Loose display hinges
There is no adjustments to tighten the hinges, they need to be replaced.
Jul 20, 2012 | Toshiba Satellite Pro A10 Notebook
Loose hing on Gateway c140xl
Faulty hinges cannot be adjusted or tightened. If the the mounting screws are loose then these can be tightened.
These WEB site hace detailed instructions on replacing faulty hinges.
Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Feb 16, 2012 | Gateway Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
HP DV 1000 Loose Hinges?
I have replaced hinges on HPs and other laptops. I have found laptop hinges have no adjustments and have to be replaced.
Jun 28, 2009 | HP Pavilion dv1000 Notebook
Hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Feb 19, 2009 | Nikon Sporter I Binoculars
How do I get the glove compartment to stop rattling?
Get it fixed under warranty. My 04 and your 06 have the same glove box. The right hinge was rattling around in mine and they replaced it no problem. Not worth trying to fix yourself :)
Jun 10, 2008 | 2006 Honda Accord
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Apr 28, 2006 | GE JVM1330BW/WW Microwave Oven
Loose Hinge
Well, if you really want to know where the screws are, they are under the "Hewlett Packard" and "720" labels on hinge of the display. However, there seems to be some "screws and glue" fix available from HP to solve loose hinge issues. I'm not very sure abt this (could be for the 728)
Sep 12, 2005 | HP Jornada 720 Pocket PC
Leupold Yosemite (8x30) Binocular Logo
67 people viewed this question
Top Leupold Optics Experts
George Merkley
George Merkley
ray gallant
Are you a Leupold Optic Expert? Answer questions, earn points and help others
