Question about Viking Kitchen Ranges
Viking broil igniter does not glow, works ok on bake cycle
There are three separate igniters, one starts the broiler and the other two are bake ingnitors left and right.
So the bake circuits ignitors work and the broil doesn't
Replace the ignitor
The part number for all of them is PB040001
Posted on Mar 04, 2009
Viking oven broiler will not ignite
Your gas valve would be my first guess. Is this broiler (and bake ) lit with a glow coil or spark probe that goes (goes click, click, to light)??
If spark probe, you will have to replace either gas valve or spark board.
If glow bar lights the broil but does not glow, then replace glow coil.
Oct 18, 2013 | Dynasty DGRSC 48-6G Gas Kitchen Range
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be...
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Mar 20, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have kenmore gas oven ignitor glows but will not light
Hello there:
It doesn't bake dot_lineone.gif Bake igniter
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
If you are certain the igniter is ok, it might be a good idea to call a professional appliance technician.
Need a new oven igniter? Click here for most common oven igniters or enter your oven model number in our PART SEARCH. ^ top clear.gif It doesn't broil dot_lineone.gif Broil igniter
When the broil igniter becomes weak or burns out, your oven would not broil. The broil igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the broil igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#ixzz1CgFQ7lBJ
Feb 01, 2011 | Kenmore 33169 Gas Single Oven
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
My Whirlpool Super Capacity 465 just made a VERY loud pop noise and shot out a blue flame. Knocked the breaker off. reset breaker and stove appears to work ok. Should I continue to use stove?
you most likely had a bake or broil burner short out. the unit may seem to heat but it probably doesnt bake right. look at the elements and see if they have a rough or blistered apperance to them. if so it probably isnt working. you can also check to see if both elements are glowing red when they are on.
try the broil cycle and if its ok then try the bake cycle, my guess is one of them is blown out.
Dec 29, 2008 | Whirlpool GS460 Gas Kitchen Range
Stoves 900GRa spark ignition
i have a 900g stoves oven how do you change from auto to manual
Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Viking oven broil keeps on
it is designed to preheat this way. after the unit cycles the red indicator light off the first time than both elements turn off. when it calls for heat again only the bake elements comes on. makes the preheating work faster.
May 05, 2008 | Viking 30" Professional Select Built-in...
Viking wall oven No ignition
There is a transformer located on the oven that generates voltage to the ignititors. You have a bad transformer or a bad connection.
Dec 21, 2007 | Viking VGS0166 Stainless Steel Gas Single...
Bake burner
It is almost always a weak bake igniter. These age and will no longer pull enough current through them to allow gas valve to open. If bake igniter comes on and doesn't light, replace it.
Nov 17, 2007 | Ovens
Kitchen Ranges Logo
454 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
