Whenever I am connecting my broadband connection to my laptop no Lan is being detected.
Hello izkho,
Your Local Area Connection network adapter may be turned off or disabled in your Network Connections.
For more assistance, please post more information and specification of your system. (operating system, computer model, connecting media, amount of network cards, etc.)
Best regards,
Ashe
PS Did you mean to post this under barcode scanners?
Posted on Aug 19, 2010
On my acer laptop, when i try to log on to Internet Explorer, the Dial-up Connection box pops up. In the "Connect to:" box i have Broadband Connection with a check mark in the "connect automatically"
To create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help.
Click on the tools at the bottom of the drop down list will be internet options.
Click on the connections tab tick in the box never dial a connection
Apr 15, 2013 | Acer Aspire Computers & Internet
Tip
How to connect wifi phone to the internet using your laptop w/ DSL...
what do you need?
mobile phone with WIFI
pc with wireless NIC (network lan which is wireless) usually the laptop have this...
DSL connection of course.
Here's the step:
just follow the images.
then after that... close the window
in your mobile phone....
scan the wlan.. then it will automatically detect the myinternet connection.. connect there and start browsing
on Jun 26, 2010 | Computers & Internet
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
Jun 20, 2011 | Toshiba Satellite A15-S129 Notebook
I have mobile broadband but i cant get connected. the error message says server proxy needs to be changed. i dont know what to do. i cant get connected to explorer but have a 3g cennection. help
If U r using Internet Explorer from windows Go to Tools -> Internet Options -> Connections -> LAN Settings and TICK automatically detect settings and remove all other ticks from all other boxes.
Mar 25, 2011 | HEWLETT-PACKARD HP 210 Netbook 1.66GHz,...
Linux 5 is not detecting my broadband modem
The connecting to internet is very easy in linux .
There are many steps but i am saying simple one
Initially configure the adsl router with ppoe over ethernet and enable dhcp address option.
Next plug the ethernet cable from router to the inteface of lan card.
Boot the redhat machine.
In the system-->Administration-->network options check whether lan card is detected and active .
If the lan card is not active activate and save
In lan card select option assign assig ip automatically
check whether ip is assigned by using command ifconfig .
Mar 11, 2010 | Red Hat Enterprise Linux ES Basic Edition
Internet explorer is not working properly
di u setup the connection ?
else do this..
open Explorer..in the menu Tools/internet options/Connection Tab/
next u can either setup the new connection or if ur using a broadband/DSL cable and connect using a LAN port check the Lan setting at the botton of that window
if u want to use setup option
click Setup/Next/Connect to Internet/Setup my Connection Manually/Conenct using my boradband connection that's always on....
if u want to use LAN setting do this
Click LANsetting/Check the box "Automatically detect setting"
OK
Let's c if this works else we will work on some other solution...
Dec 20, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Thinkpad 760el how can I connect broadband preferably wired
You will need a LAN network card in your laptop, it may already have a LAN port connection on the laptop.
First you need to decide what type of broadband connection your require DSL (it uses your phone line) or a cable connection.
You need to signup to an Internet Service Provider in your area that can provide a DSL or cable connection. Select a broadband plan that suits your requirements, be aware that some ISP will charge additional fees for exceeding your monthly download limit.
The ISP may also include a DSL or cable modem with their broadband plan.
The ISP will supply a setup CD to install and setup your broadband connection.
Oct 25, 2009 | IBM Computers & Internet
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
All LAN Ports are ON
Arunk, When you say the electrical characteristics of the new A/C adaptor are the same as the old one did you check to ensure the amperage and the polarity of the power plug is the same as well?
Apr 03, 2007 | NetGear WGR614 Router
Computers & Internet Logo
David Payne
David Payne
