Question about Cell Phones
When i turn on phone it comes up with a blue backgroup asy SIM BLOCK and 911 in bottom corner but can't move past that screen
  • 21 Answers
Sim blocked means that you have blocked your sim by entering wornd puk code too many times. now u either buy a new sim or go to ur network providers costumer care center if u want same no. and they will issue u a duplicate sim & they will charge u ofcourse
Posted on Aug 19, 2010
Not allowing me to call or text or receive calls and texts- not sim problem as sim works in other phones
You've tried the SIM in other phones which was an excellent idea...
Is the SIM carrier the same as the phone carrier? i.e. AT&T SIM in an AT&T phone? If it's different carriers the phone may be locked to a different carrier than the SIM. Is it a prepaid phone and you're trying to use it with a postpaid SIM account?
Are there indications of function on the screen? Such as the phone handset with a red line through it or an airplane icon? e.g. airplane mode may be turned on which turns off the wireless functionality and leaves you access to the other handset functions like games, apps, music player. (some phones will ask you if you want to turn off airplane mode when you try to use something wireless, but not all...)
Make sure of the orientation of the SIM when you place it in the phone. Not all phones insert in the same direction. There should be an etching somewhere nearby on in the socket itself that tells you which way the flat corner should go.
Can you still use 611 to call customer service and/or does it say SOS or 911 only on the screen somewhere?
It's possible the phone is bad in some way, but there are other issues (as above) that would be worth pursuing before you call customer service...
Dec 18, 2010 | Cell Phones
WHEN YOU TURN IT ON IT SAYS SIM BLOCK ...EMERGENCY CALL WITH ...SOS AT THE BOTTOM RIGHT HAND CORNER
To unlock the SIM card you need the PUK code.
Please contact yourphone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Dec 04, 2010 | Cell Phones
Blue images on lcd tv
optical block failure
Feb 22, 2010 | Televison & Video
Blue coming thru sony hdtv wega
you have a bad optical block depending on model may be under recall call sony
Jun 29, 2009 | Sony Televison & Video
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
1994 RCA P52753 Rear Projection
Sounds like the screen asy has failed causing the color to change from black and white,turn your color all the way down and see it the picture is green,blue,or red,if so the asy is bad or the tubes are getting alittle weak,the asy is in front of the set behind the speaker grill,there is a access panel to remove and the asy has 6 controls to adj.,only move the ones that are marked screens below them,this asy is black and is only 4 inches square,do not move any adj. on the tubes
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
Blue hue on bottom of screen We have the same problem. A blue hue extending the bottom of the screen and now is working its way up the middle .
call SONY at 800 222 SONY and explain it to them and be prepared to have your TV fixed for free !!! the projection block is faulty do to outsourcing on that part for a limited number of tv's an mine was 1 of them , SOny took care of everything !!! good luck
Feb 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
White Screen on Razr, What is a "Strip Problem"
Before you open it and look inside it check to see if the magnetic switch is stuck. Check it with a kitchen magnet to the upper righthand corner of the keypad. There is a magnet in the lower righthand corner to activate it. Do some of the function work when it is closed? If they do then it is not the cable but the switch. Does the outside screen look the same as if it is closed then it is this switch? Could be a bad one, something stuck in there, or it could be stuck.
May 09, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
