Question about SanDisk Sansa e250 MP3 Player
8gb sandisk completely frozen screen is on but will not turn off
  • kakima Aug 19, 2010
    If you have a microSD card installed, remove it. Press and hold the power button for fifteen seconds before releasing it. Does this do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having gone over a month without a response, I assume my suggested reset solved the problem.
Posted on Sep 23, 2010
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    How do I know the sandisk is fully charged
    I just bought a Sansa 8GB Clip, when the battery is completely charged the yellow battery icon (at the top right of the screen, to the right of "Connected") stays solid and is not animated, with the center horizontal bar completely filling the inner section of the icon. While it is charging the center horizontal bar is animated and slides from right to left. At no time does my battery icon turn green.
    Jan 19, 2011 | SanDisk Sansa Clip MP3 Player
    I have just disconnect my Sansa Fuse 8gb player from my pc and it has frozen - any ideas ?
    Having received no response in over a month, I assume this is no longer a problem.
    Jun 27, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
    Fuze locked up and failed this morning
    attach the USB cable then Press and hold for 20 seconds the ON button & the Play button(>||)
    Feb 05, 2010 | SanDisk Sansa Fuse MP3 Player
    I have a 8gb sansa view and up until 2 days ago it would come on
    Recovery for the Sansa View is described on the Sandisk site in 3 steps:
    1. Reset the device:
    http://kb.sandisk.com/app/answers/detail/a_id/188
    The reset is meant for switching the player off completely, before going to the recovery mode.
    2. Force recovery mode:
    http://kb.sandisk.com/app/answers/detail/a_id/197
    Recovery mode is meant for recognizing the player on the computer and making backups of files from player to the computer, before clearing the device while updating it to the latest firmware.
    3. Update to the latest firmware:
    http://kb.sandisk.com/app/answers/detail/a_id/304
    Updating the firmware is meant for completely erasing the players' drive and putting new software on it back again.
    As you follow the instructions of the last step you'll require the "Sansa Firmware Updater".
    It can be downloaded with the next link:
    http://kb.sandisk.com/app/answers/detail/a_id/156
    Sep 21, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
    Format 8gb sandisk micro sd problem
    Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
    Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
    Sansa player is frozen with the blue ring illuminated
    I had same problem a while back..
    Solution is to Hold the on/off button in "turn off" position for about 50 seconds....
    that's it....
    Apr 26, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
    Frozen on the sansa screen
    try to reset it by pushing and holding the power button down for at leaset 30 seconds or remove the back of the machine via 4 small screws and remove the battery and replace it and see what happens
    Mar 26, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
    Sansa View has a "ink blot" graphic and a white background when I turn it on.
    if its an inkblot you broke your screen..... the same thing happened to mine and i'm still trying to find a place to repair the screen.... if i find anything i'll tell you
    Oct 11, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
    Sansa e200r
    my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
    Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    20 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
