Question about Glyph GT 050Q Hard Drive
Hi I'm Q, My Glyph does not appear at my desktop. I'm using Macbook pro. It has started making noise. data must be recovered. help please, thanks.
  • 3,153 Answers
Http://www.fixya.com/support/r4247716-usb_device
Your answer should be in there somewhere as it covers most of the issues with portable hard drives
Posted on Aug 19, 2010
  • Project NOMAD
    Project NOMAD Aug 20, 2010
    how did you get along ?
Transferring data/programs from Mac book to iMac using Ethernet cable. All was going well till last minute, and it has been stuck on that for 3+ hours. Don't know what to do. Help please Elise
Assuming the MacBook has FireWire, get a firewire800 cable. PLug it into both Macs FireWire ports. Shut down MacBook, restart and hold T key = target disk mode. MacBook will appear as any other mounted external drive on your desktop. *From there, you can either manually drag files over or open Migration Assistant on the iMac and migrate user/data/ apps.
Jun 04, 2016 | Apple MacBook Pro Laptop Computer with...
My MacBook Pro 2.2ghz intel core duo won't boot. When I use the system disk to attempt repair it can't. I get error 45NS/1?4000000:TGOD-86.00. Please help! Terry Gillespie
Boot your computer in Target disk mode if you have another computer around, so you can treat the HD of the Macbook as an external.
Another possibility which would cost you more but is probably a bit safer on your data is to get a new drive, install it (a Macbook, having a user swappable HD, makes this easy) and do a fresh install of your OS on your Macbook from your disk. Put your HD in an external case and only try to get your precious data off of it when your machine is stable and reliable.
Thanks for using Fixya!
Sep 19, 2008 | Computers & Internet
Need to transfer data from old computer to new computer
You have a bad situation. Only a mac repair pro can help you in this case as it's hard to arrange some tools to solve the problem. A pro can gain access to your emac hard drive and free up some space or transfer your data using special tools and knowledge. Thank you and good luck.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Oct 17, 2014 | Apple eMac Desktop
Data lost, how to recover
Pl try Disk Drill. Download free from www.cleverfiles.com and follow the instruction.
Jul 18, 2012 | Apple MacBook Pro Laptop Computer with...
How do we find the flash drive on macbook pro?
Thank You for using FixYa
When you plug in a flash drive on a macbook pro you will see an icon appear on the desktop with the name of the usb flash drive
Also, by going into the finder, on the left hand side of the screen you will see the connected drives. It should be under your hard drive.
Hope this information was helpful
Jul 18, 2011 | Apple MacBook Pro Notebook
My mac book won't start up properly. I turn it on and then a white screen appears with an image of a folder and a question mark in the centre. Please help!
Sorry for your issue. I hope that I can help.
This icon means that your Hard drive is either unreadable to it cannot find the startup information on the drive. Either way, there is a good chance that you cannot recover your data. If this Mac is still under warranty, immediately take it back to the apple store (even if you bought it online) and they will fix it immediately and try to recover your data. You can make a service appointment here: http://www.apple.com/retail/geniusbar/
If this is out of warranty, here are the things you can try at home to solve this issue.
1) You'll want to restart the mac to be sure that this isnt a one time occurrence.
2) Start up with your system DVD (or CD) disc that came with your Macbook, then use Disc Utility to check the hard drive. Disc Utility will verify that the HD is unreadable.
3) Purchase one of the available data recovery programs out there (google and chose one that suits you. If you have backed up your data, skip this step. If disk utility shows the HD as unreadable but you have a backup, then either take to apple for a replacement HDD or purchase from a retailer and install yourself. Here is a guide for the macbook HDD install. Not a very difficult fix.
http://www.macinstruct.com/node/130
I hope this helps.
Jan 18, 2011 | Apple MacBook Mac Notebook
Ticking noise
Ticking noises are indicative of major hardware failures. As no HDD manufacturer actually warranties data, if you have important files on it your drive, you will likely need the help of a pro.
If you have all your data backed up elsewhere(including on the Mac), contact Iomega and have it replaced under warranty.
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cci/product.php
If you do need files recovered, let me know as well as your region and I will recommend a good location.
Chris
May 22, 2009 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
Computer will not recognize my 120G Glyph Netdrive when connected
check for the power and data slot sometimes wires are loosely connected also try to find appropriate driver as per the make of hard drive
May 08, 2009 | Glyph NetDrive (ndfw1b-80) 80 GB Hard...
G-Tech G-Drive Q 1TB. Four months old, only several hundred gigs of data on it. Used primarily for video editing with Final Cut Pro. PLugged in, attached to MacBook Pro today. Without warning, drive made...
The platters on your drive collided, the only way to recover is a professional company. Google Hard Drive recovery, you will get several companies, be prepared to pay $300-500.
Mar 25, 2009 | Computers & Internet
Glyph GT 050Q Hard Drive Logo
359 people viewed this question
Top Glyph Computers & Internet Experts
David Payne
David Payne
Are you a Glyph Computer and Internet Expert? Answer questions, earn points and help others
