Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Fridgidaire dishwasher its flashing PF code, what does this mean
  • Anonymous Jun 12, 2008
    Frigidaire model #PLDB998AC1. Error code PF is flashing with sanitize and heat dry lights. Dishes are getting dried. What PF means...is it heater problem?
  • 4 Answers
POWER FAILURE
Posted on Jul 10, 2008
What is the meaning of a flashing cf code?
Electrolux support site doesn't show a "CF" code. "PF" is Power interruption.
http://www.electrolux.com.au/support/troubleshooter/
Jun 03, 2015 | Electrolux 24 in. EDW5505EPS Stainless...
What does fridgidaire dishwasher error code pf mean
Usually the PF code means a power failure. You should check the wiring to the machine for loose wire nuts or wires with missing insulation touching each other or the side of the wiring housing. (You'll need to remove the access panel at the bottom of the dishwasher to check the wiring.)
If the wiring is fine, check the switches in the door latch. The white wires should test fine for continuity. If those switches are fine, then the control board has a wiring fault. Replace the appropriate parts. If your dishwasher is under warranty, contact Frigidaire.
If you add a comment with the model of your dishwasher, I may be able to help you find the replacement parts.
I hope this helps.
Sep 21, 2014 | Dishwashers
FDB4315LFC2 runs then stops and flashes pf ?
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I am getting error code PF on my LG LDF6810ST, what does that mean?
PF means power failure. You are having a power supply problem. Check to make sure that the plug is connected properly. Check the junction box on the lower right corner behind the kick plate to make sure the wires are connected properly. If your dishwasher is 5 years or older, remove the front door panel and check the wire harness in the door liner for any broken wires. Good luck
Jun 17, 2011 | LG LDF6810ST Stainless Steel Built-in...
The initials "pf" come on and prevent our fridgidaire dishwasher from continuing it's cycle. What is the problem?
"PF" generally means Power Failure. First, be sure that the door is latched tightly. Vibration may loosen the latch causing the unit to stop. Also check your circuit breaker. Flip it to the "tripped" position and firmly back to the "on" position.
If this model is an "electronic" unit (for example uses a touch pad for programming), there may be a loose connection somewhere in the wiring prior to or at the junction box under the dishwasher. The electric "noise" generated there might confuse the dishwasher's computer. Best to have an electrician look at this.
Aug 10, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
My frigidaire dishwasher is blinking lights and a
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
Fridgidaire dryer stops with code PF
pf isd power failure
with so many differant possiblities
it would be hard to nail it down here
but i would check my outlet chord and termianl post
where the chord connects to the dryer
one or more of the connections could be loose
Jul 01, 2009 | Frigidaire Electric Dryer
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
446 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
