When turning system on for use "e61" appears on display and stereo returns to standby mode
  • 3,083 Answers
I could only find one stereo error of this type, and perhaps it will apply to you and your situation:
http://www.geekstogo.com/forum/topic/255580-toshiba-qosmio-f10-reboot-and-cpu-error/
Sorry I could give more info, but had no make and model number.
Not sure if FixYa would let you reword the question, but you might try, it would help us. Good luck, and hope this helps.
Posted on Aug 19, 2010
  • Tom Carson
    Tom Carson Aug 19, 2010
    I will add to the old post. When a device gets an error message, it's because the cpu isn't "initializing"- that is, something isn't right with the turning on sequence of the unit. It can be anything as simple as a bad switch, or sensor reporting to the cpu, or it can often be a problem with the power supply, or any bad part drawing too much current. In that case, the unit automatically shuts down, to prevent further damage. Often, one can fix the problem by studying the unit, but service is often required. The service manual sometimes states what the errors are, and mean, but they are a general description. The problem can often be a related issue, or even something else masquerading as the other symptom. It's almost always time-consuming and cumbersome to try to fix the problem, and one often needs special equipment, including a service manual and schematic to get the job done. My advice would be to take it into a reputable service center, and get an estimate. Then you'll know where you stand, i.e., whether to have it fixed or replaced with a new unit. If you read this, you can replay, and if you can include the make and model number, that would greatly assist us in helping you. Hope to see some more information, and will check on it, thanks!
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
On standby mode the display shows 4 dashes,when power button is depressed display reads good-bye and returns to 4 dashes.why wont amp switch on
seems like the amp could be malfunctioning with its logic board having some issues i cant say much since most logic boards arent always easy to repair...
Feb 23, 2017 | The Audio Players & Recorders
How do i reset the hk3770
Place the receiver on Standby mode so that the Power Indicator turns amber. Press and hold the front-panel Tun mode Button for at least 5 seconds until the receiver goes on and a reset message appears in the display.
Mar 01, 2015 | Harman Kardon Harman/Kardon HK 3770 stereo...
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Fm stereo stopped working; no stereo beacon, no sound
Hi... try factory reset: while holding down VCR/DVR button ,press the ON/STANDBY button. "Clear" will appear on display ,and receiver will enter standby mode. :)
Jan 20, 2014 | Onkyo TX-SR876 Receiver
Hi, I have a samsung cell phone R450 that says silent mode activated and I don't know how to disactivated can you help me please?
Silence the tones your keypad makes when you press a key.
To enter Silent Mode:
In standby mode, press and hold . # button,“Entering Silent Mode” briefly appears in the display and your phone returns to standby mode
To exit Silent Mode:
While in Silent mode and standby mode, press and hold # button “Exit Silent Mode” briefly appears in the display and your phone returns to standby mode.
Adjust the Ringer:
1. In standby mode, press the volume key on the right side of the phone up or down. Options are:
Ringer Off
Vibrate
Low
Low/Medium
Medium
Medium/High
High
Vibrate/High
2. When you are satisfied with the setting, press OK.Your phone returns to standby mode.
Thank You
Aug 17, 2010 | Cell Phones
How to change turn-off time from 20 minutes?
Power Save mode allows your machine to reduce power consumption
when it is not in actual use. You can turn this mode on and select a length
of time for which the machine waits after a job is printed before it
switches to a reduced power state.
1 Press Menu until System Setup appears on the bottom line of the
display and press Enter.
2 Press Enter when Machine Setup appears.
3 Press the Scroll buttons until Power Save appears and press
Enter.
4 Press the Scroll buttons until the time setting you want appears
and press Enter.
5 Press Stop/Clear to return to Standby mode.
Jun 28, 2009 | Xerox Phaser 6110 Laser Printer
Rs2100 bookshelf stereo
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
Jun 06, 2009 | RCA RS2100 Shelf System
Sony LBT W5000
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
May 29, 2009 | Sony LBT-W5000 Shelf System
Philips magnavox fw-c1 3cd, 2 cassette, am/fm stereo
To stop the demonstration mode
• Press and hold stop (on the system
only)
for five seconds when the
system is in demonstration mode.
ª The demonstration will stop.
ª "DEMO OFF" is displayed.
ª The system will switch to standby
mode.
Feb 27, 2007 | Philips FWC1 CD Shelf System
21 people viewed this question
 Grubhead
Grubhead
