Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
When i turn my tv on, it takes about 25 minutes before turning on?
  • 566 Answers
Hi heaven :)
To answer your question;
What is most likely happening is that some components(capacitors) in the power supply/deflection circuit of your set are getting weak and will need to be replaced.
And it will take longer everyday to come on , until it finally quits.
I could tell you to look for bulged capacitors but this is good for recent lcd tv`s and only knowledge of the workings of the internal circuits and proper tools will solve that problem.
Sorry to be the bearer of bad news but this will need to be repaired by a tech. no matter what some online expert may say about it.
Posted on Aug 19, 2010
  • Jacques Marin
    Jacques Marin Aug 19, 2010
    Good luck for the repair.
PANASONIC PT-61LCZ70 when the set is turned on it takes a minute to power up then its on for a few minutes then the picture and sound turn off and the green power light flashes 25 times and the set turns...
Hello, have you replaced the lamp, it sound like the lamp is failing, it may also need the fans cleaned (the main reason for pre-mature lamp failure). Replace the lamp with a genuine Panasonis or Osram lamp only....tks
May 26, 2014 | Televison & Video
Magnavox 25' floor model # rh4952AK01 comes on than after 10 minutes it turns off. turns on again than after 5 minutes it turns off again
Sounds like circuit over heating. Use a room fan to cool it might help. Keep the TV on to burn in and get rid of over heating.
Nov 22, 2010 | Televison & Video
Is there an on line manual for element 32inch . The tv turns on,but after 10 minutes of being on the sounds stop working . Even the remote is unable to turn the tv on andoff. the only way to turn off...
Betty I have repaired a few of these. The biggest problem is capacitor location 2455, which is a 25 volt 47Mf capacitor. This capacitor is dry and the voltage is rising and shutting things down. Also resolder Q7461 and Q7463, these are transistors. Take this note to your local TV tech to fix your TV! Thanks for asking me...repairs are near!
Aug 21, 2010 | Philips 27PT543S 27" TV
The tv takes 25 minutes to turn on. it shows no signal, makes loud crackling noises and then turns on
i would look at the power supply as it sounds like the caps in it are getting weak
Oct 14, 2009 | LG Z37LC6D 37 in. HDTV LCD TV
Samsung LNT4061fx does not turn on
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Nov 20, 2008 | Samsung TXG2547 25" TV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
Durabrand Television
cold sorters that means needs to sorter it again
Nov 13, 2007 | Durabrand DWT2405 24" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
