Question about Dishwashers
I have a GE quietpower 3 and I cant get the door to shut. There is a green light on that says clean. There are no dishes or anything in the way of the door. I have no idea what is going on and I really do not want to phone my landlord. Please help!
    Problem Solver:
  • 10 Answers
The door latch is probably in the shut position. you need to move it to the open postion.
Posted on Aug 19, 2010
FILLS, DOES NOT WASH, THEN DRIES
GE GLDT690TBB Fully Integrated Dishwasher with 7 Wash Cycles Including SaniWash and SpeedWash, Nylon Racks, Stainless Steel Interior, Countdown Display and QuietPower 56 Quiet PackaBlack- Recent Questions, Troubleshooting & Support
Oct 07, 2015 | GE GLDT690TWW Fully Integrated Dishwasher...
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
GE Quietpower 3 Dishwasher does not stop running when door is open. I'm really tired of getting splashed in the face because I forgot a plate. *head desk*
Haha. Sorry but happened to me once. The door switch has gone bad. Get a new door switch and you'll be fine.
Jan 31, 2010 | Dishwashers
My GE Quietpower 3 has blinking lights, goes through a short cycle and shuts off. How can I either reset or fix? I've already flipped the breakers.
To re- set can take up to 90 second's depending on the cycle, the door has to remain locked or it will not re-set. Our's had not been installed correctly, it had to be closed very hard to get it to lock, it was doing the same thing as your's. Hope this help's. That beeping is annpying.
Aug 13, 2009 | General Electric Adora GHDA670N Built-in...
GE QuietPower 2 has three lights flashing, and won't work
Its the reset cycle... give it a few minutes, and it will be ready to go..
Apr 20, 2009 | Dishwashers
Dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Ge quiet power 3 troubleshooting
I have a GE Quietpower 3 dishwasher and let me tell you it is the worst dishwasher, hands down that I have ever owned. It is not quiet and it certainly does not have any power to clean anything. Or so i thought. After reading a few of the posts on this site it dawned on me to check the drainage. I took the whole drain assembly apart. Cleaned all of the gunk out of it. Then went for the drain hose. It was just about a clean as it was brand new. Then i reexamined the drain and found that it did not drain into the Garbage disposal like I am use too. Instead it had to make an immediate 30" climb into a PVC drain that sat just below the underside of the countertop. I rerouted the hose to dump into a bucket and ran the dishwasher. Guess what??? All clean and no residue. I am off to Lowes now to get the clamps and such to drain the dishwasher into the disposal. I still think this dishwasher is the worst I have ever owned and think GE should give that Six Sigma save a few pennies on one DW and the company can save hundred of thousands, at the expense of a customer spending hours on fix-it sites to find out the company cheapened the pump, a rest! However, for all of you that just want to fix your dishwasher, try draining it into the Disposal now before you blow your pump out.
Mar 08, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
