Question about Philips Televison & Video
My PHILIPS Matchline TV - 29SX8776 having vertical output problem. Please help, I need the service manual . many thanks .
  • 901 Answers
Check the vertical out put IC circuits. Go by IC number and search in Google. You will get a application circuit. From that you can make out.
Check the PCB copper tracks. Some times its get oxidized and opens.If found open join the ends, with a insulated wire ( end to end).
Also search typing service manual Philips T V model No. in Google. For some models service manuals are not available. Search by IC part no. will be faster.
Posted on Aug 19, 2010
NTV Scree
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 28, 2010 | Televison & Video
Philips model no 29pt8319/57r
Can you tell me some more then "power supply fault". I need some more information ...
Feb 23, 2010 | Philips Televison & Video
Generic problem for all Standard Televisions
your problem is from east west ckt . there is a transformer used in this ckt which Dry solder and works inttermittent ( shrinks & expend ) . resolder this transformer . iam working with philips ......... enjoy
Sep 21, 2009 | Televison & Video
Black line across screen
module problem take it to a Authorized dealer or a NESDA dealer service manuals hard to say if available since analog TVs are slowly going away and parts well another story might as well go buy a new HDTV set as a CET no garuntee how long it will be analog TV parts will be discontinued. FCC has alot to do with it.
Apr 16, 2009 | Televison & Video
T.V.
chances are its your vertical output ic it resoldered or its defective and needs to be replaced if you would like I can post you a link to get a service manual for your tv with free online tech support
Apr 23, 2008 | Philips 55PW9363 55" Rear Projection...
Toshiba 32 SDTV
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 23, 2008 | Philips 25PS40S 25" TV
I dont find philips RC2033 code.
Don't know if you have the original codes or not, but here are the codes for Phillips TV's from the original manual. Hope this helps. Try them one at a time and see if they work.
002, 009, 102, 109, 309, 402, 408, 502, 508, 807, 901, 914.
Good Luck,
Chris :-)
Nov 10, 2007 | Philips PM-8FS LCD Touchscreen Remote...
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Televison & Video Logo
239 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
