Question about Garden
Igniter does not work. I cannot find one anywhere.
  • 905 Answers
You didn't mention what model / year / engine you are having problems with, so this will be generalized somewhat.
Assuming that you are referring to the ignition module / magneto, you may able to find a used one from a small engine repair shop. The shop may also be able to order an aftermarket replacement as well. If the unit that you need is just absolutely not available, then you might have better results looking for an ignition upgrade (point / condenser to electronic, etc).
Posted on Aug 19, 2010
Where is the ignition relay in an unidentified vehicle?
It could be anywhere , need to know make model an year vehicle ! Not all vehicles have a relay for the ignition . Ignition ? switch , ignition system ? Explain !
Nov 26, 2015 | Cars & Trucks
Igniter locks out
Ignition lock out will happen if the heater expects it to ignite, all things appear to be good, but ignition never happens. Check what the heater does not Know: is gas shut off valve open? Has the gas line been worked on - was the pipe opened up anywhere, like at the union? If so, then there is air in the line and air will not ignite. So, the gas line needs time to have the air purged or you can prime the gas line, but the best suggestion is to have a Professional do this!!!
Jan 31, 2014 | Jandy Pool & Spa
Oven igniter
Check with an appliance parts supplier to identify the oven and the correct igniter.
Jan 09, 2014 | Tappan TGF320 Gas Kitchen Range
It wont turn over....the battery, alternator, and starter are fine.....could it be the ignition?
Could be the ignition. First check around the dash and look for a light that says security. If you see this light anywhere, that will explain the starter not working. Check out this link for info pictures and solutions http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 05, 2011 | 1992 Oldsmobile 88
I cant get the key to turn in the ignition.. what can i do to fix this?
your ignition is probably bad. I had one of these problems before in a 02 the ignition locks up and won,t go anywhere I work on cars all the time but this one i left alone i spent $75.00 and had a lock smith change it i bout the new one and he changed it I do not have much information on removel but the ignition probably needs to be changed
Mar 05, 2011 | 2001 Saturn L-Series
1995 dodge ram 1500, battery is good, no power at all anywhere including the horn and headlights. could it be the ignition switch? thanks in advance!
It sounds more like a bad connection to the battery. Lose terminal, Broken cable are both posibilities. The head lights and horn should work regardless of the ignition being on or off. Check all your connections to your battery and you should find the problem.
Jan 08, 2011 | Dodge Ram 1500 Cars & Trucks
Top burners work but the oven is not working. I assume this is not a pilot light but an electronic ignition. Is this a typical problem with this range?
Well not sure how long it has been in use,but igniters will go bad anywhere from 5-15 years depending on use and if the stove has been moved or dropped.The igniter is very fragile and when you look at it the crack that stops it from working is very small and many times is hard to find.Well hope this helps.
Mar 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My new ignition module doesn't have TH, F1, F2
no, the replacement ignition module should be an exact replacement for the old one.
Nov 09, 2009 | Pentair MINIMAX NT TSI IGNITER
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
