Question about Maytag MAT13MN Top Load Washer
Maytag a412 wiring for drive motor.
I took my machine apart because the belt was loose and it would not spin right. I think I fixed the problem and thought I had marked all the wires but now it will not work. Does anyone have a diagram of the wiring or give me some help. This is an old machine but has been really good.
    Genius:
  • 1,073 Answers
Look inside the console the wiring diagram will be in there
Posted on May 02, 2008
Washer won't spin, what do I do
Check the lid or door switch this is the usuall issue with a washer that won't spin. The other is a blocked pump or clogged pump filter.
Apr 30, 2011 | Maytag Washing Machines
MY MAYTAG WAS SPINNING BUT SLOWILY. NOW IT WON'T SPIN AT ALL. THE LID SWITH IS GOOD, WHAT ELSE COULD BE PROBLEM?
it could be your agitator troubleshoot the following to isolate the problem: Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel. 2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator. 3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor. 4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt. 5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring. 6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Feb 15, 2011 | Maytag Performa PAV2200
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
5
6
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
Belt Tension
If you are sure the belt is slipping, you need to replace the belt. Mine was making a growling noise that sounded like it might have been a slipping belt but it turned out to be a motor drive problem. I fixed mine with a motor/control board kit (ebay) for $155.00. However, there was a note with the kit that indicated that the symptom on that particular model might have been simply a bad cable connection at the motor end of the cable. The wire lugs are crimped-on in the motor connector and could work loose - the motor jumps around quite a lot during spin start-up...
Jan 31, 2009 | Maytag SAV5710 Top Load Washer
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Model # mav7700 AW wont drain
Dear Customer
Please perform the following
Please rate this,Thank u
Dec 16, 2008 | Maytag Washing Machines
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Maytag MAT13MN Top Load Washer Logo
343 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
