Question about Samsung Healthy Living Bsp 4007 Premium Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector
Can I get a replacement 13-17 inch cuff for this machine?
    Scholar:
  • 192 Answers
Yes, the actual website sells them as does ebay and amazon
Posted on Sep 06, 2010
Replacing leaky cuff
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
press the helpful button and follow me on fixya for more tips
Blood Pressure Monitors Parts and Accessories
Blood Pressure Monitor Replacement CuffWalgreens
http://www.walmart.com/c/ep/blood-pressure-cuffs
OMRON Healthcare Blood Pressure Monitoring
Feb 03, 2016 | Health & Beauty
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
Neither of the cuffs on the Homedics S18729 Ultra-Deluxe Automatic Blood Pressure Monitor work. They do not fit well around my arm and constantly slip while inflating. I don't know if it is a design flaw...
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Apr 01, 2011 | Walgreens By Homedics Automatic Blood...
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
SOFTWARE PROBLEM DURING PUMP FUNCNTION SO MANY ERROR I WANT UREGENT SERVICE PLESE CONTACT NO. & ADD. SERVICE CENTER IN AHMEDABAD
What brand of BP Monitor?
Is this a personal BP monitor?
Or is it a hospital BP monitor?
Well.. you have to check the cuff to see if it's OK. Most of the errors are because of the cuff which has a balloon inside the cuff.
It depends on your model.
On some models you can take off the cuff line. Check if there is air coming out from the BP machine. If there ir air, it must be probably the cuff.
If both the cuff and machine is OK, then the problem must be the machine calibration.
Is it electronic or manual BP?
Hope it helped.
God Bless You!
Feb 05, 2011 | Health & Beauty
We have a large adult cuff. The index is in the "select adult cuff" zone. Is there an adult cuff for this unit that is interchangeable ( so we don't have to purchase a whole new unit...just a...
If your arm circumference suit this "large adult cuff" and the machine give good result, you dont need to change the cuff. Otherwise, you can just ask for replace with just a regular size cuff 22 - 32 or 36mm
Jan 06, 2011 | Mabis Health & Beauty
When attaching the end connector to the cuff hose, it was done incorrectly. to correct it made the hose about an inch shorter. Does this change the accuracy of the readings?
no..... The machine is operated based on pressure, no matter how it is there, so short or long, you just have to make sure the cuff is big enough and you are fine..... Guy
Sep 04, 2010 | Samsung Healthy Living Bsp 4007 Premium...
What's error code 05?
it means it is unable to take blood pressure. Could be wrong size cuff, hole in cuff, cuff attached improperly, cuff not attached at all. if you need more assistance on this, call 8009894909 ask for Jeff or email at wats@mesasales.com
Oct 22, 2009 | Welch Allyn Spot Vital Signs Monitor with...
Reading are much too high, normal BP is 104/50, monitor reads 130/60
if your arm is too large for the cuff it will read high. most cuffs are made for small framed people. try wrapping it around your lower arm and postion it about 2-3 inches above the wrist. use the wrist to take the b.p.
Jul 27, 2009 | 3M Mabis Adult Aneroid Blood Pressure...
Small cuff size
Use a sewing machine and shorten long cuff by 1" or as much needed to fit your arm. Make sewing opposite side of BP sensor on the cuff.
Jun 04, 2009 | Omron Auto Bp Monitor with Easy Wrap Cuff...
Samsung Healthy Living Bsp 4007 Premium Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector Logo
141 people viewed this question
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
