Question about Honeywell Programmable Thermostat Heater
I cant get my thermostat to go on from 40 degree--to 69,but it will go on from 70 -- to 80
    Genius:
  • 1,970 Answers
Mcdevito75 here, If this is at an initial Start up it"s normal, if the unit thermo will not kick in at 65--69 after the unit has been running a while, you may need a re-charge of freon.
Posted on Aug 19, 2010
Is there an internal adjustment screw on the thermostat in a gwhd5000 air conditioner or any Analog unit to get it to cool down to 40 degrees or so?
normally the adjustment was on the knob on the front
40 degrees f is equal to 4.4 c which is fridge temperature
and 40 degrees c = 104 f
air conditioners run best at 25 c =77f so it is pointless getting it any lower as you will be too cold to be comfortable
Oct 31, 2016 | Goldstar Heating & Cooling
Change celsius farenheit
40 degrees C is 104 degrees F.
Jan 01, 2014 | Heating & Cooling
My rv refegerator freeezes as if it was the freezer as low as twenty degrees any help would be appricatedThanks Brian
sounds like you need a new thermostat. refrigerator section should be between 34-40 degrees. is the temperature in the freezer ok? what setting do u have the thermostat set at?
Feb 04, 2011 | Dometic RM2652 Refrigerator
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
My 1992 accord does not blow.heat when outside temp drops below 40 degree.
If you have heat when its above 40 degrees most likely your problem is a bad thermostat, when it gets VERY cold out the engine cannot reach proper operating temperature to maintain heat quality because the thermostat is more then likely stuck in the open or partially **** in the open position....
Dec 07, 2010 | 1992 Honda Accord
OVEN TEMP. VERRIES 40*
The problem is probably caused by the oven thermostat that has gone out of range.
If it is out 40 degrees where ever you set it, then you can compensate by setting it 40 degrees lower, or alternatively, replace the thermostat.
Trust this helps you.
Dec 10, 2009 | Whirlpool RBS275PD Electric Single Oven
Heating & Cooling Logo
59 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
