Question about Dishwashers
Need to put back the lower spray arm and housing - need a parts diagram to see what goes where
    Problem Solver:
  • 10 Answers
What brand is it
Posted on Aug 19, 2010
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
My Indesit dishwashers lower spray arm comes off resulting in flooding do I need new arm support
Yes. The water pressure in the hydraulic system is very important.
If more water flows through the hydraulic circuit of the lower nozzle, then probably that the upper nozzle will not rotate which will cause poor wash results.
Dado
Oct 25, 2015 | Indesit Dishwashers
How do I remove the lower spray bar
The locking nut is a large plstic housing under the spray arm. You have to turn it (usually counter-clockwise) about 30 degrees to release tabs that keep it secured. Look at the pictures of the part at ;
http://c.searspartsdirect.com/lis_png/PLDM/G0606383-00005.png see item 454
If you cannot access this link, go to the searspartsdirect.com , and search dishwashers by your model number. Select any of the models that appear. then search for "spray arm". Select the sprayarm item in blue, then hit the back button and the diagram lists will appear. (Keep hiding the popup help windows.) Select motor pump mechanism. In the picture you can see the locking tabs on the lower inside edge of 454 that lock onto the outside tabs of part 450.
Keep an eye on that washer 453 not to lose it.
Nov 17, 2014 | GE GLD5800L Dishwasher
I cannot get the lower spray arm back on. How do you do it?
There is a little plastic thumbscrew- wing nut thing in the center of the spray arm. This meets with a female coupler that sits inside the plastic arm assembly that gets bolted to the floor of the dishwasher. Maybe you forgot to put this part back right or maybe it's not seated correctly? If that female part is there, the lower spray arm just screws down from above.
Nov 20, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Need a diagram of how to put the lower spray arm witha tower back into the bottom of dishwasher Maytag model WU284
I think you are looking at item 1 in this diagram.
Hope it helps. Please rate the solution if helpful otherwise post a comment.
Nov 16, 2010 | Maytag Dishwashers
Du1145xtpq top spray, and upper spray arm don't
sounds like the chopper is plugged or broken. remove the lower spray arm by holding tab with a set of plyers and turn spray arm counter clockwise. then where the middle spray arm attaches at the back of tub remove screw. turn the housing on pump to the right side of the machine( its easier to pull top rack out a bit so that whole housing can move) it will turn a little bit to be released from top of pump. then take out the torx screws that hold the housing and filter on. in the sump there will be one or two more smaller torx screws remove those and remove coverings to the chopper. check to see if the mesh is plugged with food and other things. clean. also check to see if blade turn with the motor impeller. if not then the chopper needs to be replaced. good luck
Dec 03, 2009 | Whirlpool Dishwashers
Water is not coming out of upper spray arms
Remove lower basket completly put a bag around the arm that goes to the back of the machine (this will stop water going to the lower arm. Put the lower basket back into the machine and set the rinse cycle, this should clear the blockage if it does not your in trouble!
Nov 06, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher lower spray arm falls off
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
Spray arm not attached
You may have stripped the threads on the spray arm or spray arm support. I believe the threads are reverse-threaded and since they are plastic, can easily be stripped if turned in the wrong direction. This has happened to me before. The solution is to replace the lower wash arm and spray arm support. You can find the parts at repairclinic.com. Just type in you model number and look for item numbers 830883 (spray arm support) and 9040141 (lower wash arm). You may also want to check out searspartsdirect.com as well. The parts will be located under the "Lower Washarm and Strainer Parts" section. The two sites do offer comparable pricing. Post back if you need further assistance. I hope this helps you.
May 04, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Need to remove wash module
You should be able to hold the spray arm and unscrew the center section to remove the entire assembly. Be aware of any washers or other parts that need to be re-installed when putting it back on.
Jun 13, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Owen Barnes
