Question about Microsoft Windows XP Professional
MY SISTEM IS RUNNING VERY SLOW AN FREESS UP IS NOT MOVING WHAT CAN I DO TO FIX IT?
    Brigadier General:
  • 10,406 Answers
1. Start the Windows "Task Manager" (use CTRL-ALT-DELETE to launch it). Compare the amount of virtual memory being used with the amount of physical memory (RAM) that is available.
Not enough RAM is like piling dirty-dishes in the sink;
sooner or later, you need to remove some of the dishes,
in order to make room to wash the rest of the dishes.
Moving those dishes in/out of the sink takes time.
Trying to use much more "virtual" memory than "real" memory also takes time.
2. Disconnect the Ethernet cable from the computer, and disable any built-in wireless adapter. Does the computer start to run faster, when it cannot communicate with the Internet?
3. Virus-scan it.
4. It's possible that the disk-drive has some "bad' spots -- Windows tries & tries & tries to write to that bad spot, which, of course, slows everything down.
5. Close unnecessary programs (WinAmp, BearShare, BitTorrent).
Posted on Aug 19, 2010
    President:
  • 2,291 Answers
Virus scan it,
choose selective start up from msconfig, delete temp files, clear history, internet cache,
run chkdisk
rsgistry cleaner extend the speeds to some extent try some of them like reginout registry cleaner
Posted on Aug 20, 2010
My engine overheat when A/C is running on a slow moving traffic or on parking.
I would check and see how much air is actually moving thru the radiator. The fan may not be running fast enough or you may have debris blocking the air flow. Also make sure the system is full of coolant and no air pockets.
Nov 03, 2015 | 1995 Jeep Grand Cherokee
Need the eletrical diagram of air conditioning sistem beacuse of burned lines
85 toy?
alldata.com has it.
free?
http://www.manualslib.com/brand/toyota/automobile.html
good luck with free, try using google for free, its a moving target so....
Feb 12, 2014 | 1985 Toyota Corolla
Growling noise front end
a dog ran over that is not dead. but stuck,poor thing...
id say get it checked with live hands, eyes and ears.
nobody on any bunny cloud can ever fix a machine that makes noise.
nobody.
may FSM manuals cover noise, about 1% and is near useless.
so i this.
are parked or moving, engine running or not, in a gear, moving what gear, does it change in turns? or up hills down, or fast or slow or what?
http://www.fixkick.com/NOISE.html
Jan 30, 2014 | 2002 Toyota Sequoia
Computer runs slow
GET THIS FIRST http://www.malwarebytes.org/ CLEAN IT I T S SAFE THE DEFRAG THE PC FOUND THE DEFRAGMENTACION IN ALL PROGRAM SISTEM TOOLS DEFRAG C AND D SEE WHAT HAPPEN
Dec 23, 2013 | Apple MacBook Pro Notebook
White quilters star 1780 is running slow, how do I fix it? Have already cleaned feed dog and shuttle, what else can I do?
You can send out to repair to have it lubricated & oiled, or you can do this yourself. Not recommended though if you have pets or kids where you are working on machine. Remove needle, thread, bobbin. There are screws underneath. Don't lose them! One drop good quality oil on moving parts so lay machine back on a towel, remove screws, keep foot pedal up on table so you don't accidentally hot it with your foot. All gears that are not greasy get a very small dollop of lubricant (Singer makes a good one comes in red &white tube). All parts moving get the oe drop oil. Put plate back on, firmly tighten screws. Never lube or oil plastic parts! A drop of oil any metal screw located on top of machine. Lift machine up and if tip can be removed, you can check moving parts needing oil there and replace lid. If front section opens--left of needle bar--open it up and oil moving parts..I usually just apply one drop oil to TOP of needle bar Close lid. Put one drop oil on shuttle hook bottom left. Never oil tension discs. Run machine with scrap of fabric to get her nice and smooth sailing. If motor sounds like it's running heavy after that, take in for service, but unless motor needs replacement, you should see noticeable improvement immediately. Good luck and hope this helps! Jimmy Remove screws on top
Apr 04, 2012 | Sewing Machines
I have waves running up my screen how do i fix that
hi
depending on the waves if it is light dark bar rolling from bottom to top it may be a defective
capacitor in IF section or interference comming
for ex:defective neon sign leaky electric power transformer etc. If it is a slow moving
wave but no bars you have a defective power suply regulator and I don't suggest you try to fix it yourself
Sep 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Moisture problem in refridgerator section of Samsung RT30MBSW1
probably the defrost system is failing .. look in back of freezer / if you can ice build up the defrsot sistem not working . also the fan of fans could be running to slow. replace ment needed . . mm
Jan 07, 2010 | Refrigerators
Windows doesn't see SATA DVD-RW drive
Hi Dave.
What version of windows are you running?
Feb 29, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
