It is a good machine and still has life. The most likely cause is loose or broken damper springs. You would need to remove the top to check. If it feels loose at the back, (the front of the drum moves up and down), it is likely the rear bearing.
Hi, your question does not give me any hints so I will try to give you some general tips. If you wash things that can not spread out evenly inside the drum, like mats pillows etc. Disable the high spin and drip dry you items or squeeze out the water by hand.
If the drum swings from side to side when rotating, one of the shock-absorbers inside the machine may be worn out, broke or loose.
If you open the lid, grab the drum and move it a bit back and forth and side to side (not rotating) it should not swing easily but with a damped resistance when the absorbers are ok.
An other experience I have made is the balancing of the feet. I had a new machine that alway moved around during the high spin, even thou I have made an extra flat surface for it to stand on. I could recognize a bumping noise from the feet.
When I pressed down the left or the right front corner with my hand a little, the bumping stopped. Then I adjusted the corresponding foot down and fine tuned it until the bumping disappeared while spinning.
Since then my machine has not moved an other mm (= 1/25").
So equal down force from the feet and no play under any of them is essential to deep it from moving around.
Hope this can help you too.
Hi, I will try to give you some general tips. If you wash things that can not spread out evenly inside the drum, like mats pillows etc. Disable the high spin and drip dry your items or squeeze out the water by hand.
You probably have a broken torsion spring. If you have a spring on a shaft above the door (usually 2 if it is a double door) then you have a torsion spring. From this shaft you have a 2 cables wound on a drum going down to the bottom of the door. If it is a single door, then this cable will be loose. If you have a double door, then most likely one spring is broken. This allows the door to open slightly, until one side is trying to lift(good spring) and the other side cannot (broken spring) Unless you are an EXTREMELY CONFIDENT DIYer then you should leave this do a door repairman as winding a torsion spring is dangerous, and can break bones or even kill. Now if your door has extension springs on each side of the track,with a pully and cable, then these can easily be replaced yourself. Check that cables are connected to the springs and the door and that one didn't break or come loose or cable off pully and binding.
move the nut and hit the drum untill you see some movement then try to move it back if still give you hard time there is adjuster in the back of the drum try to loose it to make the drum free
Most front loaders are pretty much the same and it sounds like your tub bearings are going bad. There is also a problem in some front loaders where the drum arms corrode and break. You won't know until you pull it apart. If you are doing the work yourself it depends on the parts you need. You can knock out old bearings and match some up.
If you are paying someone, it may be cheaper to buy a new washer..
drum lose need more on that drum should move side to side all around if its not draining something blocking the pump if drum is lose its the basket drive block busted
