Question about Nokia 5800 XpressMusic Smartphone
When i insert the the charger into into the phone, i get not charging.
    Genius:
  • 1,040 Answers
It could be the problem of the Power IC or charger itself. First the change charger and see the result. If not charging then Power IC problem, get it serviced... Hope this has helped you... Thanks..
Posted on Aug 19, 2010
Set is not getting charged
Hi, when a phone does not charge, possible cause forphone not charging is,
: The charger,
and the charging port.
The charger might cause phone not to charge if it is damaged.You can test the charger with another phone if it will charge to confirm if the charger is working.
The charging port can also make phone not to charge, it's located at the low end of the phone where the charger is inserted in the phone.
You can check both to confirm which is faulty.
I think that will help.
Take care.
Oct 02, 2010 | Motorola Mobility RAZR V3x Cellular Phone
My BB Curve will not charge via wall or pc. I've tried several different chargers, but none helped
Hi, When a phone does not charge,it means that either the phone charger or the charging port where the charger on the phone is being inserted.
You can use another charger to test if the charger is the fault.
And also when you check for the charger and still does not work,that means the charging port of the phone is bad and will need replacement.
Take care.
Sep 26, 2010 | Cell Phones
I am having troble with my phone charging!
Hi, when a phone has a charging problem, it's either the charger of the phone or the charging port where you insert the charger on the phone is faulty.
First get another charger and test if the phone will charge.If it does not charge after replacing the charger, that means the port where you insert the charger on the phone is faulty and will need to be replaced.
Phone is a little bit complicated, you can take it to a skilled personnel on phones to help you change the port so you can be able to charge the phone again.
Take care.
Sep 26, 2010 | HTC Hero Smartphone
Phone won't charge, usb music sync on screen when charger is plugged in!
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 25, 2010 | AT&T Nokia 6555 Cell Phone - Black
My phone won't charge
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Charging fault
Phone not charging.
Take care.
Aug 31, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My Nokia 2310 suddenly switched off. It didnt switch on again. I tried putting the battery(of problem phone) into another cellphone, the battery works fine. I tried to charge the problem phone, but is not...
I tried to charge the problem phone, but is not showing any activity upon inserting the charger jack. Other phones are getting charged using the same charger.
Any idea of what the problem could be?
Jul 29, 2008 | Nokia 2310 Cellular Phone
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Nokia 5800 XpressMusic Smartphone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
