Question about Epson WorkForce 600 All-In-One InkJet Printer
Several times I M TRAYING TO FAX PAPER ,LETTERS, DOCUMENTATION ....ETC...ETC....BUT ALWAYS I GET THIS RESULT ERROR 0404----ERROR 0407--ERROR 0400 ......
Well. I just got frustation the last 2 hrs trying to fax using my workforce310 through Ooma (nopay/basic) service. Finally, tried the unconventional way and got it to work several time without any errors. I did the opposite of the instruction (1) turn ECM to On and V.34 to On. (2) dial with *99- (you can get the dash by pressing redial/pause button) and then the 10 phone digits, including the 1.
The only message I got after is that my fax has been sent in black&white because the reciver fax is not color capable. Isuspect error 0404 is to indicate this problem. Hope its help.
Posted on Oct 27, 2010
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
I cannot copy and print a document on 8"X14" plain paper. No problem with 8"X11 1/2" plain paper
Scanner: dot2.gif optical resolution: 2400 x 4800 dpi /19,200 x 19,200 dpi interpolated dot2.gif 48 bit color depth
maximum document size: 8 1/2 in x 11/11/16 in dot2.gif Copier: dot2.gif copy speed for text documents: up to 30 copies per minute in black; up to 20 copies per minute color dot2.gif reduction/enlargement: 25/400 percent dot2.gif Fax: dot2.gif color or black and white faxing dot2.gif stores up to 40 numbers in speed dial dot2.gif built in memory for up to 100 incoming fax pages General Features: dot2.gif automatic document feeder holds up to 30 originals for copying, scanning, or faxing multiple documents dot2.gif Ethernet port for connecting multiple users in a computer network dot2.gif 2 picoliter sized ink droplets for fine detail 4 individually replaceable ink tanks dot2.gif ChromaLife 100 inks for long lasting photos dot2.gif Full photolithography Inkjet Nozzle Engineering /FINE 1,600 nozzle print head dot2.gif paper sizes: letter /8 1/2 in x 11 in, legal, credit card /2/ 1/8 in x 3 3/8 in, 4 x 6, 5 x 7 in, envelope, photo stickers dot2.gif high speed USB interface dot2.gif 18 15/16 in W x 9/ 7/16 in H x 18/ 1/4 inD dot2.gif weight: 22.3 lbs. dot2.gif Part Number: 2186B002
you have to select the paper size from the computer while giving printout from computer and apply the changes you make.and while copying the page from the scanner you have to change the printersettings by clicking the menu button in the printer.
Oct 04, 2008 | Office Equipment & Supplies
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
Incoming fax error paper miss match
Based on the machine you have a single tray (not including the manual feed tray) either the document being faxed is legal and you have letter sized paper or in the machine or the Paper handling options on the machine need to be corrected. I would contact the person sending the documents to confirm what Type of paper they are faxing. Letter, Legal, A4 etc..
If you hit the menu button go to paper handling and see what your settings are to confirm they are set correctly, just to make sure your machine is not causing the problem.
Oct 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
No paper in traY
make sure the tray is set for letter size, many times the handle moves and the settings on the tray change, so the paper moves back to the settings of legal paper, so when the printer tries to load paper, it cant.
Apr 13, 2009 | Brother MFC-9440CN Laser Printer
Canon super g-3 copier
need to know what kind of fax this is
Sep 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Printing off the internet
where is here? If you dont use standard letter size paper do you use A4? If so, you must change the settings in the printer so that the default paper size in the tray is set for A4. If this is not the issue let me know and we can try something else. John
Mar 02, 2007 | Canon imageCLASS MF5750 All-In-One Laser...
Epson WorkForce 600 All-In-One InkJet Printer Logo
1,274 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
