Question about Aiwa CDC-MP32 CD Player
The battery on my car ent dead and now my AIWA CDC-MP32 keeps displaying "please unplug auxillary plugs"
    Brigadier General:
  • 3,513 Answers
An auxiliary input allows you to select an external source and play it through the cd player's amplifier. It's often used for iPods and MP-3 players. Typically you just need an inexpensive patch cable that connects the headphone output from your portable player to the input on the CD player. After that you can select "AUX" as another source like CD or Tuner, and whatever's playing on the portable unit will be heard through the speakers.
Auxiliary inputs can be on the front or the rear of the CD player. Front aux inputs are typically 3.5mm stereo plugs, similar to a small headphone jack. Rear aux inputs can be RCA jacks or a 3.5mm jack. If you have a CD player with a rear aux input, a cable needs to be connected at the time of installation. Then the other end can be routed to whatever location in the vehicle you want to keep your portable player while you're using it with the CD player.
Front aux jacks are more convenient for quick connecting/disconnecting the portable player, but they tend to wear out over time.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Posted on Aug 19, 2010
  • gloriahale Aug 19, 2010
    The auxillary port is on the front of my in-dash AIWA radio/CD/MP3 unit. I have never used the auxillary port. The AIWA currently is off but the security flap is open. When thee ignition is turned on the radio plays, but I can't sswitch to CD or try to eject the CD without it locking up the unit with "Please remove the aux plugs" displaying in marquee fashion. The only thing I cna do then is to turn off the ignition switch and then the display continues for about 15 seconds and then shuts itsself off.
    When the batteery went dead I had to get a jump start and I think that started the whole rCD problem. I found my manual and it said that if a CD does not operate properly then press the reset button with a pointed object, so I used a streched out paperclip anad reset the unit. It then powered down and I turned off the ignition AND finally the security flap closed properly!! I started the ignition again and the flap opened and I now have my AIWA working properly. NOTE: I had to reset all settings I had previously done, sincee the reseet put them back to the original defaults.
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Aiwa cdc-x116 radio presets do not keep memory after I have been away an hour
do you have the yellow wire going to a constant power source?
Dec 15, 2010 | Aiwa CDC-X116
Just had aiwa cdc x204 stolen from car but they left wiring harness intack. Cannot find this stereo anywhere. Is there another Aiwa or make that uses same wiring harness?
Most modern car stereos all use a standard plug (the name escapes me at present) so virtually any stereo should just plug in...
If your not sure, pop in to a motor parts place such as halfords and ask them to take a quick look at the wiring in your car... they will tell you weather it is standard or not...
Aug 27, 2010 | Aiwa CDC-X204 CD Player
Dim radio/cd player display
The Bulbs have blown you can get special bulbs from the renault dealer have to pull off to of dash to fit
Dec 04, 2009 | Aiwa CDC-MP32 CD Player
Aiwa CDC-X207
hi yellow go in left bottom corner
Jul 12, 2008 | Aiwa CDC-X204 CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Wire harnest order
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
Nov 04, 2007 | Aiwa CDC-MP32 CD Player
AIWA CDC-X115
Check BOTH of your power connections and your ground too. Make sure you actually have 12v at each connection and don't have a blown fuse etc. If you are lucky then you will solve the problem. Good luck.
Apr 29, 2007 | Aiwa CDC-X115
Aiwa CDC-MP32 CD Player Logo
179 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
