Question about Philips 20DV6942 20 in. TV/DVD Combo
My Philips 20DV6942/37 tv/dvd player randomly turns on and off. If I leave it plugged in it will turn on randomly..and if I have it on..it will turn off and on and off and on randomly.
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips dvd player
Turn off the night mode on the Philips:
1 In ‘AUDIO SETUP’, press OK to enter
the submenu.
2 Press 3 4 to highlight {Night Mode}, then
press OK.
3 Press 34 to highlight one of the options
below:
ON
Select this to level out the volume. This
feature is only available for movies with
Dolby Digital mode.
OFF
Select this when you want to enjoy the
surround sound with its full dynamic
range.
4 Select an item and press OK.
Posted on Sep 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: VCR will not turn on.
Remove top cover of the VCR. Then look near the back where the plug-in and power supply is. There should be a little glass fuse. You should keep that fuse and take it to the store and replace it with same exact one. If your VCR can be self-repaired, than this is the only thing you can try.
Posted on Mar 11, 2009
scoobydoorul
  • 21 Answers
SOURCE: We have a philips up-grader dvd player and get color distortion
I would try hooking something else up to your tv that is hdmi compatible. If your tv looks fine, then you know it would be the dvd player. If it's the dvd player, then I would suggest getting a different brand completely. I have had alot of bad experiences myself and other people as well when it comes to the philips brand
Posted on Apr 07, 2009
  • 10 Answers
SOURCE: Philips DVD connected to SET TOP Box with W/R/Y
Change the video resolution format from HDMI set up menu. This way you can know that if Player and TV supports/displays any one or some of the resolutions and if you can get a video on TV.
Posted on May 11, 2010
  • 8909 Answers
SOURCE: We have a Philips Magnavox
It sounds like you have a standard problem.
Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
Check to see what is required and set the DVD player accordingly.
Hope that helps.
Posted on Dec 10, 2010
Why won't either of two TVs turn on?
Try unplugging them and holding the power button down for 20 seconds or a minute or something. Then plug them back in and turn them on. It might work. Otherwise, are they under warranty?
Jul 31, 2015 | Philips Televison & Video
Philips DVD connected to SET TOP Box with W/R/Y cables. DVD connected to Philips TV via HDMI. Turn on DVD and TV screen says "Format Not Supported"? Help
Jan 05, 2010 | Philips DVP3982 DVD Player
I have a new lg tv and I can't get my dvd player to work? Please help! The dvd player is connected and turned on when I press the play button the green light turns on but It does not play on the tv nothing...
is it possible that you just need to adjust the TV to the proper channel? some DVD players default to ch3 others to ch4and if your using the av jacks make sure you haven't actually either plugged them into the input jack on the DVD player or with the new flat panel TV's you probably have a large number of input choices it is possible that you may have misplaced the inputs to ones that are close but are really meant for something else...
Dec 21, 2009 | Philips Magnavox DVD/VCR Dual Player
I am trying to hook up my dvd player to my dvd recorder can any one hellp me
The easyest way is to use a RCA cable (the red, white and yellow) on the DVD player you should have only one set (red,white and yellow) plug that cable into the input to your DVD Recorder IN plug another cable to the OUT on the Recorder to your TVs, RCA inputs(if you have front A/V jacks on your tv that would be a great place to start, rear is fine) Now turn on your TV to it's A/V channel.( maybe video 1 etc..) Turn on your DVD Player and put in a pre-recorded disc in the DVD Player, Turn on your Recorder find the A/V channel for that Maybe Video1 or 2.
Hope This Helps
Nov 03, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
Oct 30, 2009 | Philips DVP5990 DVD Player
One half black verticle screen
Manufacturer Philips Part Number 932224850682 Description LCD DISPLAThis part is no longer available
Aug 20, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Hdmi port
Philips has a complex HDCP key on its HDMI ports that makes it a bit "glitchy" when compared to other manufacturers. Usually the problem can be fixed by swapping the ends of the HDMI cable - the end that is plugged into the TV should be plugged into the Philips, and then end that is currently plugged into the Philips should be plugged into the TV. This is called "hotswapping," and will turn off a specific HDCP setting that is interfering with the functions.
Also, perhaps first even, make sure the Philips source is set to HDMI - press the HDMI button on the Philips remote.
-Tha Mp3 Doctor
Sep 17, 2008 | Philips DVDR3576H DVD Recorder
Cant turn off progressive scan
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
Aug 24, 2008 | Philips DVD 622 DVD Player
Magnavox dvd player turns off
try turning the dvd player off and leaving it unplugged for 5 to 10 minutes then plugging it back up
Dec 28, 2007 | Philips Magnavox DVD/VCR Dual Player
Philips 20DV6942 20 in. TV/DVD Combo Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
