Question about HP DeskJet 6122 InkJet Printer
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine HP cartridges, so I'm dismayed it hasn't fixed the problem. The self test sheet comes out fine...
  • michelle912 Aug 20, 2010
    I have had several computers since I bought this printer, and I don't have this utility installed and don't know where the disk is, I just always download the drivers. I searched on the HP site and other places and don't see where I can download it.
    Brigadier General:
  • 10,406 Answers
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Posted on Aug 19, 2010
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
My printer works fine except for the photos. The pictures that print out have vertical stripes that are lighter on the picture. what is causing this? and how can I fix it?
go to the printer properties,servicess perform print head/nozzle clean two or three times then check if not resolved check which color caetrige effected stripes replace it.
Sep 19, 2011 | HP PhotoSmart 7960 InkJet Printer
I have an HP Deskjet 6122. Cannot get documents
Your printer needs some manual servicing.
It's advised that you leave it for a qualified technician to do that.
From the problem you described, the encoder sensor may be causing this problem.
Mar 10, 2010 | HP DeskJet 6122 InkJet Printer
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
Printing problems
Unfortunately there is little you can do to troubleshoot hardware malfunctions like this you describe. Especially on inkjet printers. You would be better off getting a replacement printer.
Make sure you take the plastic guards off the cartridges, other than that there really isn't much more you can do.
Aug 12, 2008 | HP DeskJet 6122 InkJet Printer
Hp deskjet 6122 inkjet not printing
try getting a new printer and replace it ask them why it has problems
Aug 09, 2008 | HP DeskJet 6122 InkJet Printer
Stripes
You could try doing an alignment which i think is a maintenance option on this machine. You should find it in the driver options. You could also look at my previous posts about under head cleaning. Look here -> http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Sep 18, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet 6122 InkJet Printer Logo
695 people viewed this question
Seeker5211
Seeker5211
