We understand that your problem is: hello, I have
We understand that your problem is: hello, I have a RCA 52 " (R52WH74) chasis (ITC222A) that wont power on .. like other posts it blinks 3 times and never comes on I have isolated the problem to power board but need pointers on how to check the the Flyback trans FYI I have already checked the continuity for 400ma fuses, cp150 and visually inspected all other capacitors...... also is there any other borad that could cause these problems?
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: RCA R52WH74 turns off 3 times
Hello Kira-chan,
You are going to have to take those capacitors out of the Tv and check them on a capacitance tester. Some digital multi-meters have them, but I would suggest using the LC102 by Sencore That way you can check the ESR, and the dielectric absorption of the capacitor. It is my suspicion that these caps are bad, but should be checked before replacing them.
In addition check the BLUE and RED CRTs for cracks around the neck oy the tube, BE CAREFUL.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jul 27, 2009
R52WH74 shuts off
The deflection board needs replacement. You would require the ITC222a chassis deflection board which is available at the following link
http://tvrepairworld.com/rca_crt_projection_tvcircuit_boards/rca_rear_projection_tv_deflection_power_boards
Mar 16, 2013 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WH74 HDTV Television MAKES NOISE POWERING ON
Thats the classic sign of a failed deflection board. You can get the ITC222A deflection board which comes with warranty and installation instructions from www.tvrepairworld.com its listed as the ITC222A remanufactured deflection board under the RCA CRT Projection Circuit Board catagory
Apr 01, 2012 | RCA HD52W59 HDTV Projection Television
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
My R52WH74 projection tv is giving me a code 9 then 5 blinks
Replace the deflection board. You need the ITC222A deflection board PSB-260 available with installation instructions from www.tvrepairworld.com
Jul 07, 2010 | RCA R52WH73 Projection Television
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
Is rca r52wh74 and rca d52w14 flyback interchangeable??
No you will need the 270125 Flyback for the R52WH74 as thats a ITC222A chassis. The D52W14 is the ITC222 and uses the 259296 flyback.they are not interchangeable
Jan 22, 2010 | Televison & Video
Rca model r52wh74
You could get into service mode and set the convergence. The only problem is....RCA decided to remove it from the menu for the R52WH74. It only runs 1 time during the first setup, according to RCA Customer Service. This is the 2nd one I've bougt in 6 years. Enough RCA Garbage!
Dec 02, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
Televison & Video Logo
434 people viewed this question
Top Televison & Video Experts
